Well it seems obvious to me now that even the 0th mode is actually affected by forming the separated channels where each wave develops on its own, within its own boundaries. As a whole it's not the same as a single wave inside an OS waveguide where the wavefronts "communicate" and sum continuously accross the whole internal volume as they develop.What determines whether 0th mode waves see a pressure differential?
So what's this phenomenon? There are steps both ways. Does acoustic impedance of each individual channels play a role as well (?). Or what's going on? The longer I look at this, the less intuitive it is...
I agree, the ripple tank sims have not looked correct to me from the beginning. Consider some of the earlier plots. They show that the outer ring of sound is moving much faster than the inner one. How is that possible? Sound travels at only one speed, not a speed dependent on which channel it's in.
The radiated sims that you do with ATH, do seem plausible to me. Not much happens until an HOM appears and then everything changes. But note that the cut-ion of this mode has moved to 15 kHz which is almost double its frequency without the vanes.
Something in the ripple tank app does not seem to me to be correct.
In this case it may be better to print it and measure than to simulate. I'm not sure even about the ABEC simulation I posted, it seems not stable enough (it's very sensitive to e.g. the vane thickness). It's possible that limits of these tools have been reached.
I created a ticket for this issue: sound wave propagation speed issue * Issue #4 * pfalstad/ripplegl * GitHub
Maybe authors could fix it.
Well this particular picture was taken already some time after a reflection off the end of the vane (due to an apparent impedance mismatch). So there's already more than one direction of the proceeding waves.
What's difficult to reconcile for me is that there should be different speeds on both sides of the same vane boundary because the path lengths are virtually equal. But who am I to say that it's not possible
I can only see that the wavefronts from all the vanes will not match each other at the end of the vanes - that seems obvious to me.
No, because the foam works in volume, whereas ABEC is a boundary element solver, i.e. it can't simulate attenuation of the sound propagating through the medium...Is it possible to sim the gedlee foam plug in ABEC? If it shows difference with the HOMs
Can you provide a definition with multiple longer vanes please? I guess this could demonstrate the issue better than the original example.I can only see that the wavefronts from all the vanes will not match each other at the end of the vanes - that seems obvious to me.
Sure -
Code:
$ 3 2000 125 0 0 604 0.00037463
S 2 251 701 251 1299 0 0.08186844405594404 0 10.000178395549446 99.9998652719957 1 0
w 0 250 700 250 1300
w 0 250 1300 254 1300
w 0 250 700 254 700
w 0 254 1300 258 1300
w 0 254 700 258 700
w 0 258 1300 263 1300
w 0 258 700 263 700
w 0 263 1300 268 1301
w 0 263 700 268 699
w 0 268 1301 274 1301
w 0 268 699 274 699
w 0 274 1301 281 1302
w 0 274 699 281 698
w 0 281 1302 287 1302
w 0 281 698 287 698
w 0 287 1302 294 1303
w 0 287 698 294 697
w 0 294 1303 302 1304
w 0 294 697 302 696
w 0 302 1304 311 1306
w 0 302 696 311 694
w 0 311 1306 320 1308
w 0 311 694 320 692
w 0 320 1308 329 1310
w 0 320 692 329 690
w 0 329 1310 339 1313
w 0 329 690 339 687
w 0 339 1313 349 1316
w 0 339 687 349 684
w 0 349 1316 360 1320
w 0 349 684 360 680
w 0 360 1320 373 1324
w 0 360 680 373 676
w 0 373 1324 385 1329
w 0 373 676 385 671
w 0 385 1329 398 1335
w 0 385 671 398 665
w 0 398 1335 412 1341
w 0 398 665 412 659
w 0 412 1341 427 1348
w 0 412 659 427 652
w 0 427 1348 442 1356
w 0 427 652 442 644
w 0 442 1356 459 1366
w 0 442 644 459 634
w 0 459 1366 475 1375
w 0 459 634 475 625
w 0 475 1375 493 1386
w 0 475 625 493 614
w 0 493 1386 512 1398
w 0 493 614 512 602
w 0 512 1398 531 1411
w 0 512 602 531 589
w 0 531 1411 550 1424
w 0 531 589 550 576
w 0 550 1424 572 1440
w 0 550 576 572 560
w 0 572 1440 593 1456
w 0 572 560 593 544
w 0 593 1456 616 1473
w 0 593 544 616 527
w 0 616 1473 639 1492
w 0 616 527 639 508
w 0 639 1492 663 1511
w 0 639 508 663 489
w 0 663 1511 690 1532
w 0 663 489 690 468
w 0 690 1532 715 1553
w 0 690 468 715 447
w 0 715 1553 742 1576
w 0 715 447 742 424
w 0 742 1576 770 1600
w 0 742 424 770 400
w 0 770 1600 798 1625
w 0 770 400 798 375
w 0 798 1625 827 1650
w 0 798 375 827 350
w 0 827 1650 858 1678
w 0 827 350 858 322
w 0 858 1678 887 1704
w 0 858 322 887 296
w 0 887 1704 919 1733
w 0 887 296 919 267
w 0 919 1733 952 1763
w 0 919 267 952 237
w 0 952 1763 984 1793
w 0 952 237 984 207
w 0 984 1793 1017 1823
w 0 984 207 1017 177
w 0 1017 1823 1049 1854
w 0 1017 177 1049 146
w 0 1049 1854 1085 1887
w 0 1049 146 1085 113
w 0 1085 1887 1118 1918
w 0 1085 113 1118 82
w 0 1118 1918 1151 1949
w 0 1118 82 1151 51
w 0 1151 1949 1186 1983
w 0 1151 51 1186 17
w 0 1186 1983 1219 2014
w 0 1186 17 1219 -14
w 0 271 1081 296 1081
w 0 271 919 296 919
w 0 296 1081 321 1082
w 0 296 919 321 918
w 0 321 1082 347 1083
w 0 321 918 347 917
w 0 347 1083 373 1084
w 0 347 917 373 916
w 0 373 1084 400 1086
w 0 373 916 400 914
w 0 400 1086 427 1088
w 0 400 914 427 912
w 0 427 1088 454 1090
w 0 427 912 454 910
w 0 454 1090 483 1093
w 0 454 910 483 907
w 0 483 1093 512 1096
w 0 483 907 512 904
w 0 512 1096 542 1099
w 0 512 904 542 901
w 0 542 1099 573 1103
w 0 542 901 573 897
w 0 573 1103 606 1107
w 0 573 897 606 893
w 0 606 1107 639 1111
w 0 606 893 639 889
w 0 639 1111 674 1116
w 0 639 889 674 884
w 0 674 1116 711 1121
w 0 674 884 711 879
w 0 711 1121 749 1126
w 0 711 879 749 874
w 0 749 1126 790 1133
w 0 749 874 790 867
w 0 790 1133 832 1139
w 0 790 867 832 861
w 0 832 1139 876 1146
w 0 832 861 876 854
w 0 876 1146 923 1154
w 0 876 854 923 846
w 0 923 1154 972 1162
w 0 923 846 972 838
w 0 972 1162 1023 1171
w 0 972 838 1023 829
w 0 1023 1171 1078 1180
w 0 1023 829 1078 820
w 0 1078 1180 1135 1190
w 0 1078 820 1135 810
w 0 1135 1190 1196 1201
w 0 1135 810 1196 799
w 0 1196 1201 1260 1212
w 0 1196 799 1260 788
w 0 1260 1212 1328 1225
w 0 1260 788 1328 775
w 0 1328 1225 1399 1238
w 0 1328 775 1399 762
w 0 1399 1238 1475 1252
w 0 1399 762 1475 748
w 0 268 1210 291 1211
w 0 268 790 291 789
w 0 291 1211 313 1213
w 0 291 789 313 787
w 0 313 1213 336 1216
w 0 313 787 336 784
w 0 336 1216 359 1219
w 0 336 784 359 781
w 0 359 1219 382 1223
w 0 359 781 382 777
w 0 382 1223 406 1228
w 0 382 777 406 772
w 0 406 1228 431 1234
w 0 406 772 431 766
w 0 431 1234 456 1241
w 0 431 766 456 759
w 0 456 1241 482 1248
w 0 456 759 482 752
w 0 482 1248 508 1256
w 0 482 752 508 744
w 0 508 1256 536 1266
w 0 508 744 536 734
w 0 536 1266 565 1276
w 0 536 734 565 724
w 0 565 1276 595 1287
w 0 565 724 595 713
w 0 595 1287 626 1300
w 0 595 713 626 700
w 0 626 1300 658 1313
w 0 626 700 658 687
w 0 658 1313 692 1328
w 0 658 687 692 672
w 0 692 1328 728 1344
w 0 692 672 728 656
w 0 728 1344 765 1361
w 0 728 656 765 639
w 0 765 1361 804 1379
w 0 765 639 804 621
w 0 804 1379 845 1399
w 0 804 621 845 601
w 0 845 1399 889 1420
w 0 845 601 889 580
w 0 889 1420 934 1443
w 0 889 580 934 557
w 0 934 1443 983 1467
w 0 934 557 983 533
w 0 983 1467 1033 1493
w 0 983 533 1033 507
w 0 1033 1493 1087 1521
w 0 1033 507 1087 479
w 0 1087 1521 1144 1551
w 0 1087 479 1144 449
w 0 1144 1551 1204 1583
w 0 1144 449 1204 417
w 0 1204 1583 1267 1616
w 0 1204 417 1267 384
w 0 1267 1616 1335 1653
w 0 1267 384 1335 347
Don't the wavefronts have to be normal to the channel walls? I suspect that in the middle of the channels we would measure exactly the same paths lengths (i.e. the average ones). Then if the wavefronts are normal to the direction of propagation, this seems to be an inevitable effect (?).
- Acoustic Horn Design – The Easy Way (Ath4)
