PeeCeeBee V4H GB
Thanks a lot Shaan, one additional question I would like to ask is, can I use the complimentary C3503 and A1381 instead of mje340/350 without affecting stability of the amplifier? Attached is the picture of the transistors and my build in progress.
Marjohn
Hi mj777,
Have used alternative transistors for MJE340 / MJE350 with the transistors KSA1220A / KSC2690A with good results. The V4H amplifier with version rev.1 and performed all upgrades that a rev.2 version requires. Adjustment and testplay went straight ahead.
Is very satisfied with the finished product of V4H. I chose to use SMPS at 800Watt (it continuously delivers 500W at 25 ° C), and the amplifier is set up as Dual Mono.
Helge
(PS! Adding photos as attachments to this post was not performed due to the fact that all photos are only stored locally)
I did try to set up the amp from the start and I noticed that with probes of the MM connected to either R25 or R26 when powering it up I get a reading of 0.0 mV even when turning it off but with power on after turning the trimmers a couple of turns I start to get a reading of mV.
After setting up the amp from the start DC offset starts from +12.0mV climbs to +300mV when warm and after that suddenly drops back to +29.0mV and there it is stabilized.
The other channel has a DC offset of -5.0mV when warm.
That is a strange behavior.
Hi giaspyr.
I just checked the pictures again in here Post 1364 and both rev 1 and rev 2 mod are there, so the channels should be stable. If the offset is behaving strangely then I suspect it is due to a faulty component. Did you replace all the trimmers in the problematic channel?
