ES9038Q2M Board
ES9038Q2M Board
Old 29th December 2018, 12:24 AM   #3461
Markw4 is offline Markw4  United States
Originally Posted by 888777 View Post
It is possible that I will not even increase the input frequency. I will enter through USB Amanero.
The best sound is with ultra low jitter DSD, IMHO. Upsampling is one way to reduce jitter, which is why I like to do it in hardware just before the dac chip. Conversion to DSD avoids the sound of the PCM interpolation filters which are not good enough IMHO if the dac is otherwise very well implemented. With all the mods the dac is pretty well implemented and the AK4137 approach sounds best of all the options I have tested. A low cost AK4137 board is only about $30, so I don't think price should be a limiting factor. Also, with upsampling to DSD in hardware, its fine to use any XMOS, Amanero, Amanero clone, etc. They all sound the same here, which is to say they are all really good sounding.
Old 29th December 2018, 12:24 AM   #3462
888777 is offline 888777  Russian Federation
I will repeat. on the schematics of the board are the same. except power supply and logic control. I analyzed the reverse sides of the boards. and figured out the schematics
Old 29th December 2018, 12:27 AM   #3463
Me too.
Old 29th December 2018, 12:29 AM   #3464
I get it .. a little jitter is very good !!! Thank! Especially since I have familiar Chinese people and they can bring me with taobao directly, not through mail. It is cheap very). I will take a clone amanero. How difficult is it to realize an input frequency boost through the AK?
Old 29th December 2018, 12:30 AM   #3465
I'm friends with a soldering iron. but raising a foot on a small chip is quite laborious.
It is also possible to avoid lifting a foot and instead cut some small traces, then solder small 30 gauge wire wrap wire on them. I have done that too and posted pictures and instructions for doing it either way. Besides, even if pin lifting fails and the MCU is ruined, it doesn't matter. We can control the dac chip with the Arduino anyway, keeping the MCU is just for convenience.
Old 29th December 2018, 12:31 AM   #3466
Me too.
And?)) everything is so bad?))
Old 29th December 2018, 12:32 AM   #3467
It is no problem at all. It is designed to do that and the firmware makes it easy. You just push some buttons to configure it.
Old 29th December 2018, 12:33 AM   #3468
MCU is it logic? is it not a chip of es9038q2m?
Old 29th December 2018, 12:35 AM   #3469
No, the MCU is a separate microprocessor on the dac board (or the AK4137 board). They all have one. That's where the firmware is to make the dac work.
Old 29th December 2018, 01:22 AM   #3470
It's good)
ES9038Q2M BoardHide this!Advertise here!
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 1 11th July 2018 02:43 AM
JLSounds XMOS USB board + AK4396 board + Direct DSD PCB ravid Swap Meet 1 29th December 2016 11:36 AM
Unknown Board DC12V TPA3116 amplifier board DIY L163-9 AUS Ben Class D 0 8th December 2016 04:05 AM
FS: Ian FIFO i2s-to-PCM board, Single XO clock board trung224 Swap Meet 3 26th November 2016 02:18 PM
Lost 1 Zv4 ckt board..looking to buy 1 circuit board Blues Pass Labs 1 22nd March 2004 10:09 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
