Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Old 19th September 2020, 04:03 AM   #5581
iancanada is offline iancanada  Canada
iancanada's Avatar
Default FifoPi Q3 - HDMI - Topping D90
FifoPi Q3 has an isolated DSD_EN signal. So I confirmed there is no problem working with Topping D90 or other exteranl DACs that need this DSD_EN signal to switch between PCM and DSD.
Both HdmiPi and TransportPi can be used for this application through a HDMI cable. A small two pin cable is also needed to connect the DSD_EN signal from FifoPi.
The only issue is that D90 has click noise when change between DSD and PCM. Just hope they can fix this issue by upgrade the FW.
Good weekend.
Ian
Old 19th September 2020, 08:17 AM   #5582
ilgavro is offline ilgavro
Great job! I have a question. I use 9038pro by diyinhk, can i use the dsd en? Or i Need some mcu in i2c?
Old 19th September 2020, 05:45 PM   #5583
Joseph K is offline Joseph K  Hungary
Originally Posted by Hanze Khronye View Post
MX037/14D, MX037/14 ?
MX037/8P looks better.
Good point.. But why not go even further.. Their MXOC series is more of the classic, MTI260 style classic timing reference oscillator..
Bigger and heavier, and consumes more than the miniature versions. Also better parameters..
Magic Xtal Ltd. development and production of OCXO, crystal oscillator, crystal oscillators, oven control crystal oscillator (OCXO), oven control crystal oscillators (OCXOs), miniature OCXO, ultra-stable OCXO, low phase-noise OCXO, high stability OCXO, high frequency OCXO, vacuum-sealed miniature OCXO, vacuum-sealed OCXO, crystals, crystal, кварцевый генератор , опорный генератор, опорный кварцевый генератор, малошумящий генератор, термостатированный генератор, термостатированный кварцевый генератор, миниатюрный генератор, миниатюрный кварцевый генератор, миниатюрный термостатированный кварцевый генератор, кварцевый резонатор, низкий фазовый шум, Products
Old 19th September 2020, 05:55 PM   #5584
In this category there is strong competition, so it could be that cost less than the small, low consumption flagship technology versions..
Old 19th September 2020, 06:02 PM   #5585
Doh.. There never is nothing new under the sun..
Here they brought up the same.
Then why did it stop there..!?
IanCanada's Latest RPi GB Goodies Impressions... and your tweaks, mods and hints...
Old 19th September 2020, 08:21 PM   #5586
A123 is offline A123  United States
Originally Posted by Joseph K View Post
I was one of those who mentioned it. I had been looking at it ~2years ago..
Just for curiosity. Yes, these are identical.
Also the phase noise parameters are equal to those cited for Pulsar..
I think the Pulsar project really was a group buy adventure.. But for some reason did not hold..
Ciao, George
Good stuff.
I'm allocating this year as my learning curve for Q3 / Accusilicon.
If all goes well, I estimate beginning of Summer 2021 I may start hunting for these clocks. Maybe earlier, but conservative estimate. Will follow a GB if one shows up.
I'm looking to build the most optimal small footprint battery power transportable Music streamer possible for personal use. Don't think that goal can be obtained without these clocks.
Old 19th September 2020, 08:42 PM   #5587
Thanks for sharing. Saves me from having to contact about obtaining more plots. I cannot believe these alternatives are available.
Please share which product you would consider most optimal with the Q3? The one closest to plug and play. I just assumed the consensus was the 14D?
I might contact Russia next month and try to get info on pricing, payment, shipping, etc..
Old 20th September 2020, 04:55 AM   #5588
Hanze Khronye is offline Hanze Khronye  Australia
Good point.. ]
Actually I mistook 1Hz for 0.1Hz, 14D looks better to me and could be the sweet-spot in their lineup for power consumption, size and phase noise.
@ A123, yes 14D. Of interest is that initial samples measured better than what became end Pulsar product (I refer to 9x.xxxx MHz). I did also find reference to Pulsar using selected 'low phase noise' OCXO from MagicXtal. The single sample which I have suggests this may be true (which runs counter to the discrepancy mentioned previously), and I'm sure there's a back-story there, and quite possibly an intermediary as well, reading between lines makes picture clearer but also introduces risk of error :-)
Regardless, a shame that Pulsar is no longer making these available in QTY 1+ to end user.
HK
Old 20th September 2020, 06:58 AM   #5589
CallMeMike is offline CallMeMike  United Kingdom
Originally Posted by carlmart View Post
Can someone tell me where the discussion over the Mezzanino power supply board might be on the thread? Around which page?
I made a search but got nowhere.
Have a look here: Mezzanine Power board for Raspberry Pi
Old 20th September 2020, 09:43 AM   #5590
HK
Yes, I do understand what You say..
Though would take that "sweet" rather 'bitter-sweet'..
The MXOCI line has 10dB lower phase noise at 1; 10Hz..
Not small difference. Actually, with 1Hz /-120dB, 10Hz /-145dB , at 10MHz, it starts to be tough competition..
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3262 20th September 2020 05:41 PM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1422 22nd March 2020 02:15 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
