Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Old 18th September 2020, 05:11 PM   #5571
carlmart is offline carlmart  Brazil
Ian,
Is there a schematic anywhere for the LinearPi and the ConditionerPi?
Old 18th September 2020, 05:14 PM   #5572
iancanada is offline iancanada  Canada
iancanada's Avatar
Thanks A123,
Please no worries. We are in the same community.
FifoPi or McFifo needs good clocks to improve sound quality, which is also what I'm looking for.
Please keep us posted if there is any update.
Ian
Old 18th September 2020, 05:20 PM   #5573
iancanada's Avatar
Originally Posted by carlmart View Post
Ian,
The most detailed technical information is the user's manual. Otherwise, it could be not available.
GitHub - iancanada/DocumentDownload: Download documents of Ian's products
Ian
Old 18th September 2020, 05:20 PM   #5574
A123 is offline A123  United States
Amazing. It looks identical to Ian's Pulsar clock shown in the Q3 photo:
10 MHz:
Old 18th September 2020, 05:21 PM   #5575
iancanada's Avatar
Exactly !
Do you have a more clear picture of the phase noise plot?
Ian
Old 18th September 2020, 05:21 PM   #5576
ilgavro is offline ilgavro
after the last message i upgrade the Ian idea.
i already change the oscillator of raspberry with huge improve. for me is better rpi4 because have gigabit lan, and non ethernet via usb.
rpi-def-3d — ImgBB
Old 18th September 2020, 05:33 PM   #5577
Originally Posted by iancanada View Post
Exactly !
Ian
Unfortunately, no. They have a PDF, but will have to contact them to see if they have any updated plots.
http://magicxtal.com/upload/uf/df1/M...D(en)%2012.pdf
A few DIY members mentioned there's re-badged Pulsar clocks out in the wild or in this case it's Pulsar OEM.
I'm just an end-user / messenger so hopefully in the next six months can learn more about this possible upgrade before getting upgraditis around that time.
EDIT: The photo in the PDF looks even more like the one in the Q3 photo. There's just no "Pulsar" stamp labeling on top.
Old 18th September 2020, 06:22 PM   #5578
Joseph K is offline Joseph K  Hungary
I was one of those who mentioned it. I had been looking at it ~2years ago..
Just for curiosity. Yes, these are identical.
Also the phase noise parameters are equal to those cited for Pulsar..
I think the Pulsar project really was a group buy adventure.. But for some reason did not hold..
Ciao, George
Old 18th September 2020, 10:03 PM   #5579
1audio is offline 1audio  United States
Originally Posted by Markw4 View Post
How does one best measure nonstationary or quasi-nonstationary distortion? Obviously, the typical audio FFT works best for measuring distortion that is perfectly stationary relative to the acquisition time frame.
An idea I proposed some time ago but never pursued-
First for this we must assume all the relevant musical information is contained in the encoded digital stream.
Start with truly random noise with a higher than musical crest factor either directly created digitally or encoded from an analog noise source.
Play the noise source capturing it with the most faithful/accurate ADC you can get. preferably with independent but exactly equal clocks. Then match the original data stream to the recorded data stream. This would be a good starting point: Audio DiffMaker
The nonstationary artifacts should show after correcting for any timebase or response errors.
What this most likely would not show are interactions in the grounding network or noise getting into associated audio equipment.
You can substitute music for the random noise but the noise would test about every sample transition possible given enough time. Its sort of a bit error rate test of the chain.
Demian Martin
Product Design Services
Old 19th September 2020, 01:46 AM   #5580
Hanze Khronye is offline Hanze Khronye  Australia
MX037/14D, MX037/14 ?
MX037/8P looks better.
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3262 20th September 2020 05:41 PM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1422 22nd March 2020 02:15 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
