Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Chip Amps Amplifiers based on integrated circuits |
Thread Tools |
#21 |
If you have lm1875 in stock, why not. I'm genuinely curious to see how you will manage the composite things. That's something I've recognized above my own skills.
Good luck with the project.
All that is excessive is insignificant. Talleyrand |
#22 |
#23 | |
Yes 00940... i read a lot and with this "project" you will not learn much by me ![]() chris |
#24 |
Hi
to be clear which supply voltage we should have for 4 R load i did a test again. to get 3Amps aout we need at 4,459R a Voltage rms about 13,37V at the resistor. i use 25V supply but with the with 450mVrms i get this current limiter. switch on_off_ on off --> i show this in the LM1875 kit thread. i go dwon with the supply 20V - this is the max off Voltage of the chip to do not go into the limiter. and here are the results: pic 1 +/- 20V supply 500mVrms in (G=27dB) 11,2 Vrms at the load of 4,459R -- clipping pic 2 +/- 20V supply 480mVrms in (G=27dB) 10,6 Vrms at the load of 4,459R -- clipping pic 3 +/- 20V supply 460mVrms in (G=27dB) 10,2 Vrms at the load of 4,459R -- no clipping - this give us a current of 2,287Amps continuous pic 4 +/- 15V supply 460mVrms in (G=27dB) 9,3 Vrms at the load of 4,459R -- clipping - supply voltage too low pic 5 +/- 18V supply 460mVrms in (G=27dB) 10,1 Vrms at the load of 4,459R -- clipping - supply voltage too low - closed to 20V supply but not enough this give us a current of 2,265Amps continuous pic 6 is the test enviroment - idle - no signal so we should calculate per chip at 4R with 2,2 continuous? chris Last edited by chermann; 14th December 2019 at 04:52 PM. |
#25 |
here is a summarize of that test
if you look at pic 3 and pic 5 you can see that the formula - look at the Vpp Vout = Vsupply - 10V is correct!!! |
#26 |
Good work as usual, Chris. The current limit kicks in at 2.3Arms corresponding to 3.25Apeak. I assumed use to 3Apeak in the initial estimations so that wasn't completely wrong.
Was this an Amazon chip or a genuine TI chip? |
#27 | |
![]() if i did no mistake at my workbench.... ![]() original TI chip...to confirm this test i will do this test with my amp boards = amp 1_2 the nichicon UES board.... |
#28 |
Hi FF
according to post 9 If we limit the supply voltage to +/-25V such that we can expect output signal clipping at 20V, the output power calculations become: SE-coupling: 25W in 8 Ohm. SE-coupling: 50W in 4 Ohm. BTL-coupling: 100W in 8 Ohm. BTL-coupling: 133W in 6 Ohm. BTL-coupling: 200W in 4 Ohm. Still respectable values. what about the Transformer ratings? 2x15VAC - 160VA-200VA -230VA for both channels chris |
#29 | |
#30 |
here is a first approach for composite .
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Composite LM1875 MiniAmp and HeadphoneAmp | bkercso | Chip Amps | 3 | 20th November 2019 12:49 AM |
Composite LM1875 stability issues | Glkjh | Chip Amps | 5 | 8th June 2019 03:32 PM |
Speaker Parallel Configuration | anoopkrajan | Multi-Way | 3 | 10th February 2018 02:10 PM |
Need help with Triple Parallel LM1875 dynamics amplifier. | danielwritesbac | Chip Amps | 146 | 9th July 2014 06:27 PM |
Honeycomb composite panel enclosure, dual opposed configuration | rhapsodee | Subwoofers | 6 | 1st September 2010 04:26 PM |
New To Site? | Need Help? |
