Arduino based LDR volume and source selection controller
Old 1st January 2020, 08:46 PM   #1221
JOIMONF is offline JOIMONF
JOIMONF's Avatar
As I said, I feel subjective listening enough balanced in the medium volume range in I use, positions 15 to 30.
But it bothers me some things:
1- each time I perform ''Adjust Bias'' I need to adjust again at some degree, I remember one time even out of the range 500/1000ohm,
2- no matter if I edit and upload the measured LDR values, always I tested same results found at min. vol. shunt / max. vol. series.
3- also I edited on firmware, down to half both Nom. impedance and Load impedance (exactly 6k/47k) but same no effect, always found same results shown on previous post.
Just I performed right now a new bias adjustement /new calibration cicle, and no success. Error 1, left series could not be calibrated.
Old 1st January 2020, 11:34 PM   #1222
zdr is offline zdr  Belgium
zdr's Avatar
Probably a typo, range should be between 500K and 1M.
Custom DIY PCBs, BOM and LDR Firmware:
https://sites.google.com/view/dacgear/
Old 2nd January 2020, 09:18 AM   #1223
JOIMONF's Avatar
Sure, I meant 500k/1M range
Old 12th January 2020, 09:20 AM   #1224
yurgs is offline yurgs
Default Freeze
Hey there, i am very happy with Nebs AIO board,
but after a year of normal operation it started showing error 20 after startup.
i tried re-calibrating but discovered that my LDRs have increased resistance up to 239r.
i replaced them with 4 NSL-32SR2 and now the controller starts without error, but i cannot change volume, change channels etc.
it seem frozen!
i checked soldering, reloaded the firmware, but with no effect. still frozen.
i measured the 5v, and it dropped from 4.96V to 4.19V.
is there any other part i need to change if switching from SR3 to SR2?
i hope someone has an idea,
i doesn't seem to be the encoder since remote doesn't work either..
Lenco L75/ Denon DL103 Shibata // Hypnotoad's AD797 Pre // LDR Arduino Controller - Aurora-DSP // chocoholic's Liteamp // Prestigeous 2 Monitor-DIY Subwoofer
Old 12th January 2020, 09:31 AM   #1225
zdr's Avatar
Looks like you have a problem with something on i2c bus that can easily mess up arduino. This bus connects display, arduino and mcp23008, so start from there. Disconnect display first and listen if arduino boots - relays should click.
Old 12th January 2020, 04:26 PM   #1226
NickKUK is offline NickKUK
Originally Posted by Vincent77 View Post
Hello,
- I/O switching is done with best quality latching relays with Silver-Palladium contacts, to avoid any degradation of the musical signal
quick question
I see that you're using Panasonic AGQ20012 - the non-latching relay part, and on the circuit board the connection for a selection is via 3+4 and 5+6. Thus the relay coils need to be operating to select the line. The non-selected lines are sat with no voltage.
Naturally this means on startup no inputs are connected.
Do you know if the relay simply carries the signal over the metal bar that contacts the metal core inside the relay coil?
During operation the selected line has a powered coil hot and possibly a contacting metal core near the signal path. What additional noise does this cause?
Also given that the coil in the relay doesn't need full current to maintain the contact - does the system back off the power to coil following selection?
Lastly - is there a flyback diode across the relay coils?
Old 12th January 2020, 09:00 PM   #1227
JOIMONF's Avatar
Originally Posted by t-minik View Post
@JOIMONF, mine is a pain in the a** to calibrate too.
It seems really temperature dependant and if I need to recalibrate it I must plan some hour to avoid error 1.
When calibration is done it works well though
Thanks t-minik, at your suggestion I performed repetitive calibration cicles, and I have succeed, so very grateful to you.
I calibrated after 5 /6 cicles fail.
I repeated twice and same, success after same aprox. 5 or 6 fail.
Old 13th January 2020, 10:18 AM   #1228
Thank you Neb!
it was enough to point me in the right direction. i checked the display fist but i found out that i somehow blew the nano during my changes on the board.
with a new nano it is working again!
i was also wondering if anyone has used big letters instead of the channel numbers in the display? BT, TV etc.
i think it doesn't work with the selected font.
my Arduino skill's are pretty limited, i know.
Thanks already!
Jürgen
Old 13th January 2020, 08:06 PM   #1229
zdr's Avatar
No, the font has only numbers defined.
Arduino based LDR volume and source selection controllerHide this!Advertise here!
Another Modified PGA2311 kit with Arduino for volume control and input selection cjkpkg Analog Line Level 29 17th September 2019 12:04 PM
Passive Preamp: Arduino based, remote control, Relay R2R, input selection maxw Analog Line Level 104 18th July 2019 10:13 AM
LDR Based Input Selection udailey Analog Line Level 27 8th November 2018 04:37 PM
Source select and passive volume for microcontroller-based preamp? vputz Analog Line Level 3 21st July 2012 11:51 AM
WTB: LDR-based volume control / pre jdubs Swap Meet 7 2nd December 2010 02:50 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
