Arduino based LDR volume and source selection controller
Arduino based LDR volume and source selection controller Please consider donating to help us continue to serve you.
Old 19th November 2018, 11:48 AM   #1111
samoloko is offline samoloko  Bulgaria
Originally Posted by zdr View Post
Fully assembled kit with PS, rotary encoder, IR sensor + OLED: 200eur , with LCD: 180eur.
zdr,
I am Interested at your fully assembled kit.
Please confirm that I do not need to bother with arduino stuff - controller Is Included and programmed.
Can you offer ballanced stereo version.
Old 19th November 2018, 11:50 AM   #1112
zdr is offline zdr  Belgium
zdr's Avatar
Originally Posted by samoloko View Post
zdr,
I confirm that everything is included, but there is no balanced version.
Custom DIY PCBs, BOM and LDR Firmware:
https://sites.google.com/view/dacgear/
Old 19th November 2018, 12:03 PM   #1113
thank you for reply
do you plan to do balanced version
can user tape down new names for Inputs and outputs without pc
Old 19th November 2018, 12:31 PM   #1114
zdr's Avatar
No plans for the moment, I do not see enough interest. I/O names change require firmware re-upload in the current firmware.
Old 19th November 2018, 12:54 PM   #1115
In order to use In balanced system Is It possible to use arduino controller to controll not just one board but also another board, etc to double outputs from arduino controller
Old 19th November 2018, 01:00 PM   #1116
zdr's Avatar
You would need two complete boards with two Arduinos that are connected either over I2C or serial, one acting as master and other as slave, and significant coding effort to make everything work together.
Old 25th November 2018, 05:41 AM   #1117
wineds is offline wineds  Australia
All I know is that there is no pop on my boards and they also mute outputs by connecting them to ground - the code just does not touch calibration relays for muting purposes. So I guess it must be the calibration circuit. It's not a good design anyway to flip the calibration during mute, but I guess it was due to limited number of relay control pins. I remember that someone in this thread blew up MCP23008 by flipping mute too often.
Also don't forget that entering calibration mode connects audio gnd with digital gnd, which is another bad idea during mute and a very good candidate for audio "pop".
Thanks Neb! Could you perhaps share your current 4x2 schematic with me so I can modify my unit to be compatible with your firmware?
Old 25th November 2018, 07:49 AM   #1118
zdr's Avatar
Iím afraid I donít have schematics as I made mods on pcb layout only, but mod is simple: use two arduino pins instead of one controlling two separate output relays that can be used as mute instead of calibration relays. One pin is old output relay pin and the other was used to control power delay relay before.
Old 26th November 2018, 05:13 AM   #1119
OK I had a look at your code. If I cut a track and run RE3 off Rel6 instead of Rel0 would that work with your code?
Old 26th November 2018, 11:13 AM   #1120
zdr's Avatar
Don't touch calibration relays. My code does not use them for mute, but they are still used for calibration. You need to take the one for power on delay instead and use it as second output relay. See pin definitions and compare them to original code, that will give you an idea.
Arduino based LDR volume and source selection controllerHide this!Advertise here!
Another Modified PGA2311 kit with Arduino for volume control and input selection cjkpkg Analog Line Level 29 17th September 2019 12:04 PM
Passive Preamp: Arduino based, remote control, Relay R2R, input selection maxw Analog Line Level 104 18th July 2019 10:13 AM
LDR Based Input Selection udailey Analog Line Level 27 8th November 2018 04:37 PM
Source select and passive volume for microcontroller-based preamp? vputz Analog Line Level 3 21st July 2012 11:51 AM
WTB: LDR-based volume control / pre jdubs Swap Meet 7 2nd December 2010 02:50 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
