Zv9
before this thread dies...
who's going to work up a PCB for this amp?
As long as Mr. Pass is cool with it. 🙂
I think a lot more people would actually build it.
Looks a little to busy for me to do it point to point...
over voltage
Hi all,
What would happen if I used more than 50 volts on the input? Does the Mosfet Q4 hold the input at 46 volts?
I'm sorry if this has been answered elsewhere. I have a 50/50 volt plitron looking for a home.
Thanks,
John
p.s. what would it take to create a balanced input?
Hi John,
As long as you provide a reference to the gate (like Zen ver 4), the output will be 3 to 4 volts less, Vgs. As you use higher input voltages then you have to account for the higher dissipation on Q4.
BDP
steenoe said:
I was thinking along those lines also, Moe😉 I am in the process to see if it is possible to pursuade Russ White into it😀 As long as it is cool with Mr. Pass ofcourse:angel:
Steen🙂
Hi Steen,
Indeed, I am very excited about the project/PCB. I am working up the schematic right now and will be drawing the PCB soon. I am still doing some reading to be sure I understand what I am doing as much as possible, but I think it will be a very fun project.
I will be looking for input from everybody, and I hope I can get as much great help with this one as I did with Twisted XBOSOZ.
Cheers!
Russ
power supply load...
I'm using psud2 to design a ps for this amp. My 50/50 plitrons may work if I use an lclc filter (10mH@.1ohm), thus dropping the voltage to around 52 volts. That's assuming the ZV-9 offers a 25 ohm load. Hence, my question: is 25 ohms correct? Now, how to lose another 2 volts... (I may be losing my marbles)
Thanks,
John
Russ, that is great news🙂 I am sure it will be a very nice project. I guess a lot of people are interested in this particular amp. It shouldnt be difficult to get help if needed🙂
I am really looking forward to see how your boarddesign turns out.
Steen😎
Re: balanced version
carpenter said:
While reading the zenlite article, I noticed Nelson created a balanced version of that amp by joining it alongside a mirror counterpart. Is there any reason this wouldn't work with this project?
It will work fine, but keep in mind that it won't deliver more
current in bridge/balanced mode.
0R47 at 3W . . . ? Most probably too small . . .
0R47 takes a role of sensing the amount of the output ac current.
By the way, as the bias is abt 2A with 50% ac current gain, max output I(rms) could be 0.71x4A . . . then, the time-evrage power is 0.5 x 4 x 4 x 0.47 =3.76W . . . I would use . . . mmm . . . 5W rating. Or, 1R 3W // 1R 3W, i.e. 0R5 6W.
jh
BDP is correct. A 2 or 3W resistor is fine.
It's a question of continuous output power, not peak. Let's be generous and say that you're pushing the amp to 20W. Assuming an 8 Ohm load, that's a little less than 1.6A. Using the I(squared)R formula for wattage, a .47 Ohm resistor will experience about 1.2W of heat.
Music being music, it's not going to run the amp to full wattage all the time unless it's grossly overdriven. An old rule of thumb says that the peaks are ten times the RMS power. If you grant that assumption, the actual power dissipation will be less than one-eighth watt.
Still, it's best to be ready for a full power bench test. Use the 2 or 3W, whichever is handy. I use a 3W in cases like this, not because the part can't take it, but so that the resistor will be more comfortable to touch if I'm prodding around in the circuit.
Resistors are robust devices and can take an absurd amount of punishment. You could probably use a .25W part for normal use and a 1W for bench testing, but they would burn you if you touched them. After a while, they would discolor. So would the board. So would your finger.
Grey
Grey
Yeah . . . I entirely agree with you about all details.
I just started my thinking from the extreme case. And, if all safe at the extreme point, we could stretch our legs and make ourselves eased. If there is apace for a bit bigger resistor and the price is minor part, why not . . . ? 😀 . . . Of course, we already have many of 2W or 3W grade sleeping in our room and like to wake them up . . . then . . . :clown:
jh
Concerning the 0.47 ohm resistor...I'd use a 5w one...
Now the question would be which type of resistor sounds best😀
But then, why not play with its value, say from 0.22 up to 1 ohm...so we'd get various AC current ratio, and maybe discover which one we like most....😎
Regards,
Vix
