Uchi Deshi said:
C1 should be best quality as you can get electrolyc cap.
Thank you, very much, for your reply.
I wonder if C1 could be a Jensen 4-pole or BHC T-network, possibly with a few cut traces?
Best regards,
Paul
Re: Re: transformer question
Paulb,
Thanks a lot!
Dennis
paulb said:
Use two of these
http://sound.westhost.com/power-supplies.htm#fullwave
connected to the same transformer.
I recommend you read the whole article.
If this is for the ZenV9, yes 40mF is enough. It has a filter on the power supply line.
Paulb,
Thanks a lot!
Dennis
I have never tried Jensen 4-pole , but they can be good choice for this purpose. It's hard to find good elco cap for this position.
4 pole caps as output caps
Unless I am very mistaken the 4 pole Jensen T caps perform some kind of filter function, at least at high frequencies - hence 4 poles instead of 2 - and as such would not be ideal to pass a signal. What you could do is to convert them into 2 pole caps, i.e. parallel the 2 positive poles, and the 2 negative poles respectively.
Hi guys
I'm stuffing the boards according to Veteran's schematic. Most of the parts I already had. Below the parts list to maybe help some of you out.
Amplifier
C1 Electrolytic Capacitor 10000µF/63V Panasonic TSHA
C2, C5, C9 Electrolytic Capacitor 220µF/63V Panasonic FC
C6 Film Capacitor 100nF/100V MKP Epcos
C7 Film Capacitor 1µF/630V MKP Angela Fastcap
C8 Film Capacitor 20pF/500V Silver Mica
R1, R2, R3 Resistor 2,2 Ohm / 3W 5% Metal Oxide ROX35 Neohm
R4, R5, R6 Resistor 1 Ohm / 3W 5% Metal Oxide ROX35 Neohm
R7 Resistor 100 Ohm / 3W 5% Metal Oxide ROX Neohm
R8 Resistor 22K1 Ohm / 1/2W 1% Metal film Dale RN60D
R9, R12 Resistor 221 Ohm / 1/4W 1% Metal film Dale RN55D
R10, R11 Resistor 1K5 Ohm / 1/4W 1% Metal film Dale RN55D
R13 Resistor 1 KOhm / 1/4W 1% Metal film Dale RN55D
R14 Resistor 33K2 Ohm / 1/4W 1% Metal film Dale RN55D
R15 Resistor 100 Ohm / 1/2W 1% Metal film Dale RN60D
R16 Resistor 9K1 Ohm / 1/2W 1% Metal film Riken Ohm
R17 Resistor 47K5 Ohm / 1/2W 1% Metal film Riken Ohm
R18 Resistor 0,47 Ohm / 5W 5% Metal band MPC-71
R19 Resistor 3K32 Ohm / 1/2W 1% Metal film Dale RN60D
P1 Trimmer 25KOhm Cermet 64W Vishay
Q1 N-Channel PowerJFet LU1014D Lovoltech
Q2, Q3, Q4 Hexfet Power MOSFET IRFP240 International Rectifier
Q5 NPN medium power transistor ZTX450 Zetex
D1 Diode 1N4004 400V/1A General Semiconductor
Power Supply
C1, C2, C3, C4 Electrolytic Capacitor 10000µF/63V Panasonic TSHA
C5 Film Capacitor 100nF/630V MKP Rifa
R1, R2, R3, R4 Resistor 1 Ohm / 3W 5% Metal Oxide ROX35 Neohm
R5 Resistor 2K2 Ohm / 3W 5% Metal Oxide ROX35 Neohm
D1 – D8 Diode HFA 08TB60 8A/600V International Rectifier
Tr1 Transformer 230V Prim / 2x18V sec 300VA Velleman
Amplifier
Power Supply
Rail voltage
Thanks GeWa!
What rail voltage are you designing to? With that transformer I get either:
-- 18 Vac rectified to ~ 25V DC or ...
-- (2 x 18) rectified to ~ 50V DC
Thanks again,
Ryan
Thanks GeWa!
Thanks again,
Ryan
- Zv9
