Zero Feedback Impedance Amplifiers
I built this amplifier in both versions with 6c33c tube SE driver and mosfet SE driver.
In general the sound is natural and "liquid" with very good details. The sound stage is very stable and accurate even when playing complex tracks. I think it's very fast and it controls the loudspeaker very well thanks to the output transformer. It's easy to get addicted to its sound. I compared it to a few other common amplifiers and I have to say they are all far away from Zeus. Listen to this amplifier for a while then if you listen to other amplifiers you will understand their problems.
I prefer the 6c33c tube driver as it gives more crispy sound but not harsh. I feel the mosfet driver a little too soft.
Hi, I built the single ended (gapped) EI and the output PP EI transformer following Susan's design but I designed and built the little input (or interstage or passive amplifier) transformer. I only used toroidal transformers in the power supply. Driver and power have dedicated PSU. And mono block design.
"increase the level of 3rd, 5th and 7th harmonics": not relevant.
"gain that varies with Icb": not relevant.
To get some parts-experiences (and listening/audible-measurement-experiences, compared with looking-measurement-experiences;-) I would replace the TO-247 MosFets with "similar" TO-220 MosFets first.
Later I would replace the TO-220 MosFets by any TO-220 bipolars.
LG
Reactions: Alessandro Dalto
Direct Drive using a Dual Voice Coil Loudspeaker
Best 2018 New Year seasons greetings.
In answer to your question:
Post # 1 of this thread shows T1 power output transformer. The attached schematic suggests using a dual voice coil woofer instead of T1. Maybe this approach is already buried in one of the 1600 posts!
Basically it doesn't work because the speaker voice coil inductances are too small and so don't couple or store enough energy to work outside the narrow watt or so of PP Class A operation from the biasing.
Attached is a scope grab showing Direct Drive and Transformer 1:1 Drive for comparison, as can be clearly seen (and heard) the 1KHz tone gets crunched by the LF one.
At low levels it sounds really great... 🙂
Best,
Susan.
  • 171231-direct-drive-tube-bipolar-test-SPH-135TC-v-transformer-tek-scope-trace-1.png
I'm still trying to understand what you mean by "To less the "soft"-ness."
Can you suggest particular types of music (or even better, specific passages in specic recordings) where the effect you are describing can be clearly heard? What change are we supposed to be hearing?
"To get some parts-experiences (and listening/audible-measurement-experiences, compared with looking-measurement-experiences;-) I would replace the TO-247 MosFets with "similar" TO-220 MosFets first.
Later I would replace the TO-220 MosFets by any TO-220 bipolars."
The methods to study will follow;-)
10k:600 is some 4:1 voltage (winding) ratio.
Reading the description, I'd have my doubts:
Quote:
Permalloy 10K:600 audio step-downIsolation transformer: mark the measured value on the transformer.High quality audio step-up transformer, imported permalloy material, can be filtered to eliminate AC noise interference,Digital killer. For a variety of high-end professionalsHIFI front stage, audio signal boost use.
It can also be used upside down,Impedance 600:10K.
The measured voltage ratio is1 to 0.6.That is to say, 10K The input voltage is 1V, and the output voltage of the 600Ω winding is 0.6V,The signal is attenuated.
But, regarding price, you can take the chance.
