Yet another Volume controlers and source selections
RC5 Tester
Hi 🙂,
Here is a code for RC5 debug
It show:
Address info + code
Command info + code
Easy to reprogram a multi ir remote when you can see the address/command on LCD
I used my ATM16 but eny other AVR can be used
run INTRC 8Mhz Disable JTAG if your chip have it
LCD 16*2
/Kim
@ Edit input text works now auto fill space on save via RC5 allmost finish code 🙂
Hi Kim!
For long time Read here all Thread about RC5 and do experiment to Learnig,
but I Flash your RC5 Tester and to start programm coming only ( RC5 Remote Read) and Display go out, I have with 3 Remote controller (Sony,Terratec and Sharp) and Do nothing, I only do other LCD configuration,
Config Lcdpin = Pin , Db4 = Portc.4 , Db5 = Portc.5 , Db6 = Portc.6 , Db7 = Portc.7 , E = Portc.2 , Rs = Portc.3
and PortD.3 ist the output from my SFH5110 and chance to experiment with TSOP 1738 and no go, please can you say why? I have all in my STK500.
Thank
stk500
Hi STK500
If te Lcd show "RC5 Remote Read" then you lcd is setup OK
This code only works with Philips RC-5 Protocol
Sony , Sharp, RCA ect do not work with this code
did you program it as INT 8Mhz CLKDIV/8 = off else it runs 1 Mhz
how did you connect the IR ? pullup 10K ?
If you look at Bascom Hep serach for "GETRC5"
you can learn more about the IR part
Here is Sam Bergmans web lots of good info about Remote IR Protocol
Hi Kim!
Thank you for you Info, Well I think one RC for (Sony,Terratec and Sharf) maybe work, I see the signal in my Oscillocope in the output of IR, but maybe you know Who find one Send RC5(Philips protocoll) to tester Software and Hardware?
My plan ist to control Led with music for my living hall with RGBW led, when in finish my project coming here in forum, open source. but with you name in the Source Programm.
bye
hasta la vista amigo!
stk500
Hi kim!
Thank you!
maybe you no me Understand, I say , I push you name in my programm Code,because I take your code programm to experiment and my project.😀
in Germany Forum ist Ok but my Job is Sound, ok, this ist one motiv to coming in Diyaudio 😀
Thank you
stk500
FarmTech HI! HI ALL!
Greetings!
tell me is there a firmware for the M16 + PGA + LCD & VU +4 in + RC5
and what scheme is used for your firmware?
I'm sorry I'm new
Hi
No its for Projetc nr.3 see post #4
and Post #348 VU-meter addon
but to get the full storry you have to read the hole Thread lots of addon is made for Danzups controller 1.6C
start at post #3 and read 🙂
I just completed building the latest Rev 2.1.b.
After I apply power, the LED reads "10", and I can adjust the volume up or down. So it seems to work. I am using the R2R settings.
My problem is: After about 5 sec, one of the relays clicks, and the LED goes off.
If I recycle power, it does the same thing again.
Has anyone experienced this, or know what might be the problem?
Thanks,
Dave
