I did not disable Jtag and setup clock to internal 8Mhz.
I am not sure how to do this. I used the Atmel STK500 to program.
I will make an attempt to do this.
Thanks for your help.
Dave
Dave
program Avr studio ?
I was able to set the Fuse bits, but I still have a problem.
As soon as +5V is applied, the display reads "10", then one second later, the display turns off and no other functions work.
Any ideas?
Thanks.
Any ideas?
Thanks.
Hi,I was able to set the Fuse bits, but I still have a problem.
Any ideas?
Thanks.
Hmm, I dont have this version so I cant give info about it
And nothing happens if you press POWER button ?
But of cause you setup Jumpers as R2R like on image
And the jumper on main-bord to for R2R !!
else contact them for help/support
Any ideas?
Thanks.
Only the power button will work after power down !
So it is in firmware and from what is telling me it is ok how that controller react .
Do not power on after press power on button ?
Please send more info for me to help you .
Hi Danzup,
Thanks for your reply.
Yes, the "On/Off" switch, S2, does turn on the volume control.
I thought the S2 switch was used to turn on an external device, like a power amp. I did not realize that after applying +5v to the board, the "On/Off" switch needed to be pushed.
I was confused.
It works now and I am continuing to built it into my pre-amp.
Thanks,
Dave
I was confused.
Thanks,
Dave
This is the truth : but the controller power up at the same time with the amplifier !
And for the time the controller is powered up so does the power amplifier .
Hi Danzup,
I have been integrating your board into my preamp, and am having problems with the remote control function.
I have tried several universal remotes that I have. I just cannot seem to get any response.
I read in an earlier post that you might have a Sony remote code version of your software. If so, I would like to try the Sony version.
Thanks,
Dave
Thanks,
Dave
I recommend to you to use the "farmtech no vu" firmware and use that firmware to reprogram the key with your RC5 remote .Hi Danzup,
Thanks,
Dave
Read again few pages on this thread and use that firmware because it is more flexible about remote control . My firmware accept only small number of RC5 remote .
FarmTech,
I looked at your "farmtech no vu" firmware to fix my remote problem, and noticed it is made for the LCD version.
I am using an LED and was hoping you could add the RC5 learning remote function to the LED firmware.
I know this is a lot to ask, but would greatly appreciate your help.
Thanks,
Dave
Thanks,
Dave
FarmTech,
Thanks,
Dave
Hi David,
I think its faster if Danzup add the RC5 edit for LED version
All my program is for LCD huges edit in code to change to use LED
Hi David,
RC5 edit for LED version, the control PGA2310, good, very grateful
Hi David,
I will do this in the future , but wait for it .
Hi tvicol
I have downloaded gerber and all other files from website. I will etch the boards in few days.
Kindly give information as how to get it working after assembling the board
viki_v2,
The document is over 50MB and due traffic limit on my website I can not share trough this forum, please mail me and I'll give you the link.
Regards,
Tibi
Regards,
Tibi
Guys, great job,
but you're using R2R linear attenuator.
Please check this topis about logarithmic attenuator with constant impedance. There should exist calculator too:
http://www.diyaudio.com/forums/pass...-relay-resistor-logarithmic-attenuator-2.html
T attenuator
stefan, how much resistors and relays we have to use to get attenuation from 0dB to -127dB at 1dB step?
Here is example of 6 bit (64 steps) attenuator calculated by me.
It is differential, because it was for Aleph-P, but you can use onle half of this for one channel.
The attenuator is for 600 ohm output impedance, for input it's too small and it must be recalculated.
- Analog Line Level
- Yet another Volume controlers and source selections
