XSim free crossover designer
I've just downloaded this and tried to play around a bit.
But I cannot get anything to happen to the curve. I.e adding a cap does nothing 😕
I'm able to affect the impedance tho.
Example:
I have succeeded to import a REW measrurement into Xsim. As I have no impedance measurement, it is 4.7 Ohm resistive anyway. Can I change the default 8 Ohm value?
Put one 11,4 ohms resistor in parallel to that default 8 ohms driver will give a flat 4,7 ohms impedance, but if you plan use a passive XO network think its important use measured non linear impedance for the driver mounted in the actual box/baffle situation and can see you have used REW for response curve, now go to REW help then "Impedance Measurement" to see how to measure your drivers box/baffle situation.
Is it possible to get coil resistance to automatically change to a higher value when increasing coil size, and go down with decreasing coil value? Like one could set the awg value for the coil and coil resistance followed automatically coil value.
When we're talking about different crossover slopes and phase shift, are we talking about the actual acoustic or electrical slopes?
In other words, say a tweeter has a natural 6db roll off, and you couple that with a cap to get a 2nd order roll off. Do we end up with a 90 or 180 degree phase shift?
