Let's get serous here. Since you can plainly see the crossover, you can plainly see it has problematic parts like electrolytic capacitors and iron core inductors.
Even if you wanted to use such parts, even if you were OK with the complexity of the XO, and even if you can read their values off the labels, are you able to determine if the replacement parts you buy are close to their values and match L and R?
Clearly there's some low freq crossing over here. Today, many of us would handle a woofer or sub by bi-amping.
B.
B.
Nothing wrong with those parts if they are used in the right way.
Nothing wrong with those parts (iron core inductors and non-polarized electrolytics) if they are used in the right way.
What does that mean exactly?
And does everybody (or anybody) who builds with electrolytics and inductors have the means (and knowledge of calculus) to measure them to see if they are anywhere near their spec and to choose matching pairs L and R? And is the chemistry of your electrolytics "charged" to their rated capacitance at the minuscule varying voltages in a crossover?
B.
For example:
Electrolytic capacitors have higher ESR than a poly cap, so this needs to consider for best results. ESR is little tricky because the value is usually frequency dependent.
Iron cored inductors may saturate and distort at high loading situation and cannot reach their rated inductance at low loading situation (mainly the bulky ones, although not a big problem).
You need to be careful where and how to use and these passive parts works fine.
It means that if the designer knew what he was doing, electrolytics and iron core inductors may well be the right (if not the best) choice of capacitor or inductor types. It's just a question of what needs to be achieved.
And does everybody (or anybody) who builds with electrolytics and inductors have the means (and knowledge of calculus) to measure them to see if they are anywhere near their spec...
I don't see the logic here. How does the type of a capacitor or an inductor relate to the equipment and knowledge available in a workshop?
...and to choose matching pairs L and R? And is the chemistry of your electrolytics "charged" to their rated capacitance at the minuscule varying voltages in a crossover?
As YSDR cogently explained, electrolytic capacitors and iron core inductors are swell little elements but not for crossovers.
Electrolytics have giant tolerance and can be off by 50% and then need to be formed when electric currents start flowing through them. Other capacitors are stable and they can come with 10% tolerance.
Now, with all the obsessive attention to careful design and issues like phase and time alignment that goes on in this forum, you just can't install a part that could be 50% wrong. You need to measure your components and match L and R.
No.
Electrolytics have giant tolerance and can be off by 50%...
There may be some electrolytics out there that come with large tolerance. But not all electrolytics are equal. Just look for parts with a 5% tolerance or so. Electrolytics are not inherently cheap junk that must be avoided at all costs.
For example, you might look at the xovers of the OSMC. The woofer filter uses a 6.8 mH / 0.2 Ohm inductor, a 120 uF capacitor, and some other parts. A typical 6.8 mH "air-core" inductor will have a DC resistance of more than 1 Ohm, which would result in a loss of efficiency and poor damping, affecting the bass tuning of the woofer / box. Only a very large and super expensive "air-core" inductor may get you well below 1 Ohm, but likely still higher than the 0.2 Ohm required for the OSMC. In contrast, an iron-core inductor will have low-enough DC resistance, allowing a better result. Except for loudspeakers that are designed for very high power levels (not the typical stuff we use at home), even a relatively small iron core will not saturate in normal use. Also, a 120 uF film cap will be unnecessarily expensive, where a suitable electrolytic will get you the same result at a fraction of the cost.
Would you really want to suggest "air core" inductors and film caps must be used for that?
Ok, time to get back on topic of the OP.
Hi is it possible to know electrical parameters of xover starting from pictures?
Yes... I used Xsim and the zip file for V1 is attached.
There seems to be a lot of driver specific tuning. I used a DC28 tweeter and DC315 woofer as driver place holders. Do you know what the original drivers were?
If you fill in the component values, using the reference designators, it would help understand the tuning.
If you have a multimeter (ohmeter) you can confirm the schematic connections. I flipped the bottom view so it matches the component view.
- Xover reverse engineering
