X-Calibre : Hot Rodding Mauro Penasa's LM3886 design
carlosfm said:
Rudi, what does 'GECO AUDIO' means?
Hi Carlos thanks for joining us.
I have lots of little gecko's around our house so i played with the word a bit - so it ended up with a variation of deco and gecko.
see i am actually a architect and i do not know much about the laws of electronics. just how to make them sound better.
t. said:
This will probably be my last chipamp project after a few more mods to this one, I'm going to try the Hypex classD modules next
Leo, I know you are a 'hardcore' diyer 😀 and you don't need kits or available PCBs to build something.
Before you go on switching your outputs [joke], give this a try.
I don't know if I'm still on time, you are the one who knows what you wanna do next, but I guarantee you very, very rewarding results.
Peter Daniel said:
And what is your reference when you compare those two types of diodes (by saying one adds, the other does not)?
Hi Peter,
In this amp the Mur860's made the bass sound slightly artificial, a bit like cranking the bass up on a graphic eq if that makes sense, it was deeper but became less defined, the high also seemed slightly rolled off (more warm) compared to the schottkies
The MUR860's do seem to work very well with the standard GC amps but they just didn't work well for me in this amp.
Its all personal opinions of course😉
Thank you Carlos 🙂
I'd love to try this as soon as I can open it:bawling:
The UCD180's have already been ordered but its something else to try, adding another to my already huge pile of amps won't hurt, its another raved about thing these classd modules so I guess its got to be tried at least
Peter Daniel said:
Hi Leo,
I was asking because in a past I was using LM3875 both with baterry supply and AC supply (with MUR860 diodes) and I noticed very little difference in tonality beetween the two.
Battery supply appeared dynamically challenged in a long run and too smooth for my taste. 😉
Hi Peter,
Well I've also took your opinions serious regarding conponents especially after trying out the polarity of the BG N caps, I'm still shocked at the noticeable difference it makes😉
Its strange that I didn't like the MUR860's in this amp, maybe its just the design😕
I admit to liking the MUR860's probably best with the GC amps though and the Schottkies better if regulators are used
T , just somehting that i have noticed. with the X the MBR 10100 were better, and with a snubber evenmore so. but you will let us know when you build yours. it was a compromise because i need to do the entrire spectrum with the amp and for that reason i chose the MUR860
NB: anybody that wants to build the amp with MBR10100 should be aware that you would not have all the bass you are used to. and if you have a small speaker system then the MBR are not recommended. but with a proper fullrange system you will be richly rewarded
Thats better, nice one Rudi😀
I'll let you know as soon as I can get the new board built, this is going to be a busy month for me😱
It goes quite for a while and all these projects come at once
Sorry to go off topic
Thats an interesting looking pre-amp Carlos
I've actually got a couple of those SMD AD815's but never used them for anything yet, I can easily modify your amp and implement the AD815 if I can find my magnifying glass and tweezers
Is there any threads with the layout? I could build this easy enough from your schematic but how did you manage to fit all the parts so close to the chip, its tiny😀
I could cheat and etch a board but no doubt its not as good as a tightly done p2p
Did you have any problem downloading the file? 😕
It's a .zip, with 3 .png graphic files inside...
That may as well be the preamp of your life.😉
I'm not joking, this is serious.
And you can use it with whatever amp you have.
Leo, the chip is not tiny, even the SMD version is quite big and relatively easy to work with.
Look at the datasheet for the pinout of the SMD version.
It has a perfect pinout.
It has the PSU pins located exactly where all the op-amps should, I mean if it was an 8 leg thing that would be pins 4 and 5.
I have never made a PCB for it, although I had the intention (but no time). My prototype (on veroboard) ended up as definitive inside my pre.
Some weeks ago Peter Daniel sent me some non-smd AD815 chips and I made this test setup.
Hi Carlos,
I could download your file but the pc would not open it, as soon as I added .zip at the end of the file name suggested by Rudi it worked fine
I've just dug out my smd AD815, your right, its not as small as I thought but I know how important the layout is so i'd like to get it right😉
Excellent work from you again and thanks for sharing😎 I'll have a dig through my parts box, I've been after a nice pre for a while, I've got Nuuks tube pre to try too.
I presume an 8v reg would be ok for the nulling circuit
carlosfm,
i remember you posted the source of your 10k pots...(the green sturdy looking ones in your non soic 815 preamp)
could you post the link again?
i can't seem to find a good 10k pot other than the panasonic ones... (in the US)
thanks,
