I am now waiting for the order from Newark.
65K3699 30 In Stock 15.42 CW02BR4700JE70 VISHAY/DALE
74C0155 10 In Stock 3.53 B0207C10K00F5T BC/COMPONENTS.
Bypass caps
Hi guys,
got a question. The bypass caps on Peters F4 board, what values can they be, and what value should they be?
thanks
andy
Hi guys,
thanks
andy
Mounting Mosfets to heatsink
If someone could make a recommendation...
I have'nt found much info on this subject. It may not really be a matter of any sort.
Is there any reason to use a spacer and a stainless bolt vs a zinc sheet metal bolt with no spacer? Looking at some pics, people seem to be using all sorts of things. Just wondering on what will least likely have any influence on the mosfet.
Sorry for the possibly rediculous question...Didn't seem to be an issue with a chipamp, but not sure if this things, or the MUR3060 rectifier needed some nonmagnetic bolts.
Thanks for any input or experiences here.
The issue here is that the spacer with a bolt will let you have
a more even pressure on the device to insure it makes good
even contact with the heatsink. This is even a lot more inportant with the to220 devices.
jrebman said:If anybody has a single stereo amp board they can part with, please contact me. I gave up a board earlier but now realize that I'm really going to need two bridged or balanced amps. I have the PSU boards, just need another amp board.
Thanks,
Jim
I have a set of boards if you need them. 20 bucks shipped.
looking for a pair
If you've got a pair of F4 boards lying lonely, please send me an email.
Thanks,
doug
Thanks,
doug
Re: looking for a pair
Had a pair but they were sold. Am into the F5 now .. Have ZV9 boards for sale if anyone is interested.
shallbehealed said:If you've got a pair of F4 boards lying lonely, please send me an email.
Thanks,
doug
Zen v9
If they are similiar to F3,I think they are. I am interested. Please email offline please.
marsupialx said:Ok, I'm feeling greedy now, sorry.
No, asking for a complete kit of boards and parts would be greedy!
I am interested in a pair of boards and PS boards if available.
Tom
Peter, as you have a lot of experience as well with the black gates: for those 4 220uF: would you recommend fk or nx types ?
THX
THX
Not much chance I imagine but would somebody sell to me two sets of F4 boards (for two stereo amps) with or without ps boards ?
Blitz said:Peter, as you have a lot of experience as well with the black gates: for those 4 220uF: would you recommend fk or nx types ?
They are both quite close and final choice will depend on personal preferrences and actual circuit.
I mostly use BG N, and in F4, I will go with BG N 100/50
BG NX are similar, but a bit more softer in trebles with slightly less refined. BG FK seemed to me always somewhat colored, and I never really used them. From whatever experienced I have with Shigaclone, FK were even more mellow, but very 'musical' OTOH.
Why not trying Elna Silmics II? They are very good sounding caps, a bit bright comparing to Black Gates N, but more transparent and sometimes this can be an advantage.
Good hint...I am already usng the silmics...you think they are more transparent than the BGs ? ? then I will skip the idea with the black gates...I thought the BG could be another upgrade and I was just curious what could come next...
BTW: I am in the process of ordering some of the texascomponents-resistors you suggested...which version would you prefer: the TX2352 or the TX2575 ?
Any other suggestion how to tweak the last bit of transparency and resolution out of this amp (it is not cool-sounding at all here at my house, very musical, very warm, very 3D)?
Frank
Frank
Hi
I'm very late to the party but with many looking into the F5 I'm hoping I can get 2 of Peter's pairs (for 2 monoblocks) within North America.
I also need 4 boards (directly or indirectly) of his PSU.
Thanks,
Dann
Thanks,
Dann
