.47 ohm 3 watt resistors
Is it needed to use wirewound resistors for the 3 watt resistors? Digikey is out of the Panasonics. They have Vishay/pheonix in stock, but @ 2.18 a shot they are more expensive than mills.
I am wondering about good sounding alternatives.
I am wondering if a metal film or carbon or whatnot will work here.
In the power supply, I think we are looking @ .3ohms (my multimeter is a bit twitchy this low, using cement type X 4). Would it be possible to use a .33 MRA-12 on each side? I dont want to tweak the voltage here, so any power supply guru's step in. 40 Mills MRA-12 .47 ohms for two monoblocks is chunk of coin.
Panasonics from DigiKey are metal oxide so metal film should be no problem here. If 0.47R is out of stock you can use any other value that is close enough, the actual value is not critical here as long as you set proper current.
In PS you have 4 x 0.47R in parallel which gives 0.11R combined resistance. A single 12W Mills should be fine here (or 2 x 0.22R, 5W )
As to the other resistors, DigiKey now carries Dales and those will fit the board (CMF50): http://dkc3.digikey.com/PDF/C081/P1782.pdf
hiii Peter
Do you still have this f4 boards ?
im interested to build this amp
How much price for f4 boards?
How much much price for PSU?
maybe i will buy your psu more
can you give me information
how much f4 output (class a) ?
if we compare with class ab
how much the output ?
thanks before peter
regards, jeffry
thanks before peter
regards, jeffry
Yes, the boards will be available, payment info was posted here: http://www.diyaudio.com/forums/showthread.php?postid=1384617#post1384617
Peter,
I would like an additional 2 F4 amp board sets and additional 6 PS board sets. Here is my tally:
Previously shipped and received: 2 amp sets, 2 PS sets
Still due to shipped: 2 amp sets, 2 PS sets
Final total of all my orders:
6 total Amp board sets (balance to ship now 4)
10 total PS board sets (balance to ship now 8)
I sent Paypal for added amounts today.
Thanks!!!
Tom
Thanks!!!
Tom
Ordering info was posted here: http://www.diyaudio.com/forums/showthread.php?postid=1384617#post1384617
5 sets left ......
5 sets left ......
