WTB: F4 PCB boards
Jase,
I think we are talking about the same capacitors. They are on the F4 amp board and are labeled C5 and C6 and have a slightly smaller diameter than C1, C2, C3 and C4. If you look at the back you will see they are connected between the input GND and the V+ and V-. You could leave this empty to have the original schematic.
If you install this "power supply" capacitor on the amp board you end up with a shorter "wire" between the power supply and the amp. Short wires are good wires.
Jim
