WTB: F4 PCB boards
Peter Daniel said:
The rectifier section is supposed to be separated and high power diodes mounted as in a picture below (they can be attached directly to a chassis for heat dissipation, isolation pads needed). The board is designed mainly for 3 pin rectifiers, but will work with other diodes packages as well. Here's MUR3060:
Hi Peter. Is there any reason why would one use a such a diode? I haven't used it before but I believe you only need 2 to make a bridge. In your photo, you used 4.
Thank you for the reply
Possibly?? Paralled, to keep the current level and not push all the current through a single pair, even tho they can handle 36amp's.
Jase
With those PS boards you can't use them in parallel, I use only one half of each diode. But you can still wire them in parallel through additional jumpers.
You cannot use only two to build a bridge, as those are common cathode type only; you would need three.
I wanted to make the options for all diode type, including 3 pins type.
