Wilmslow Audio - Prestige platinum
I can understand that but have you considered that with the WA passive x-over being over £300 and a Behringer CX3400 being just £72 at Amazon you'd have £250 towards the extra amps needed for active? And if you subsequently go active the passive x-over will be redundant. In fact I will have a set of passive x-overs with no purpose in life soon (because I'm going fully active)! You might make significant savings on speaker cable too depending on amp/speaker placement.
To start with I'm going passive.
OK so I've got a 100W amp on the bass.
Mid crossover is at 400Hz.
Assuming that the bass will max out at 40Hz, that's approximately 3.5 octaves. The passive crossover is 12dB/Octave, that leaves me to believe that the mid is some 42dB less than the bass.
And as the tweeter crosses over at 3.8kHz, the tweeter is some 6.5 octaves or some 78dB lower than the bass.
Am I correct here ???
I'm not familiar with the F4 & 5 you mentioned earlier but I assume one is more powerful than the other.
In which case I'd suggest getting the bigger of the two and use it for mid&treble duty until you can swing the next smaller one and go fully active.
All you need is a little bit of restraint with the loud button until then but you probably have already enough to fall out with the neighbours.
How powerful are those things anyway?
The only change from standard I'm going to do to start with is to mount the crossover externally so that all three drivers have their own set of terminals on the rear of the speaker with nothing but wire from the terminals to the drivers themselves.
I've caught the bug. It's like an AIDs virus, once caught you are dead meat.
Andy once said to me, "Can you hear the difference", my answer was a definite YES.
I've always wanted to build something, I wasn't sure what. I'm no carpenter nor can I design something myself. I just found the WA Platinums in one of my searches and the seed was sewn.
A couple of big advantages to going active:
1. The power amps won't require the current capability of a stand-alone amp designed to drive a passive crossover. A passive loudspeaker can have all kinds of nasty dips in its impedance plot and a good power amp is designed to handle these. So large current capability, big power supply, big heatsinks = expensive. That's why your Passamp is so good with your present B&Ws.
An active system has the amps directly connected to the drive unit, which is a much more uniform load - usually 4 or 8 ohms minimum. No high current capability required - in fact, it would be entirely wasted. This considerably cuts down the cost, not only on the parts mentioned earlier but even on cases - unless they're on show, the amplifiers can be built into almost anything, even the base of the speaker.
Lack of high current requirement means you can reduce cable costs too (if exotic cables are your thing).
Plus, as you've said, you can tailor the size of amp to the drive unit. The Rod Elliott point about power distribution is a good one.
2. His other point is that an active system sounds twice as loud as the power going into a passive system. So 3x 50 watts will sound like 300 watts going into a passive system. Quite a few studio actives have surprisingly modest power amps in them (Genelec, for example).
I have commercial active speakers here and wouldn't revert to passive. The stop-start control and headroom takes the system a big step closer to sounding real, particularly on orchestral music.
Footling around with a DIY design, I costed up running the DIY speakers passive vs active. Using Gainclones and Rod Elliott's x/over boards, the cost of active was not significantly higher than a reasonable grade passive, which would only have been junked later.
Thanks Colin, an excellent read.
Now, I've got the Aleph4 which is undoubtedly the better quality of my two amps.
I've also got a "Hi-Fi" amplifier that was born from an article in one of the electronics mags many years ago, I seem to recall it is reasonably good and about 150W.
As there is more detail in the Treble / HF range, am I correct in assuming that the Aleph would be better in that region leaving the Class AB amp to drive the bass ?
