In fact, I am quite sure I had some professional equipment using such OP-AMPS and it was quite a pain to find them as a spare parts. Defenetely they don't look DIY friendly.No, but I'm sure they have a distributor.
Samuel
Good hint anyway, thank you.
To drive an ultrasonic transducer.what is your application?
You can drive these floating, right? It will be much easier (and less dangerous!) to build two 100 Vpp amps than one with 200 Vpp.
Samuel
If the transducer is a piezoelectric element, expect it to be a pure capacitor (low impedance current sucker) except near resonance, where it will display the usual resonant circuit peak/dip impedance curve. Potentially a tough load for conventional amplifier designs. Most people use an inductor and operate them as resonant tanks, or some variation thereof.
Samuel
Sir, in fact I was hoping to bridge two 200Vpp amplifiers to get 400Vpp.
And the drive signal is just sinusoidal? Then a tuned amplifier might be a solution, as suggested by Conrad Hoffman.
I've quickly sketched some (non-tuned) amplifier which would bring the basic performance, but making things short-circuit proof etc. is difficult.
Samuel
Samuel
knowing the load is a ultrasonic transducer is a start - already changes estimates of load – from the V alone we can assume a piezo type - there are magnetostrictive transducers too
even among the piezo there are ceramic and plastic, wideband, narrow, launching waves into air, water or moving mechanical structures with struts, stacks, benders - sometimes requiring DC response to hold a deflection
the more you can tell about the application the better our ability to recommend appropriate circuits - what frequency response? pulsed, continuous, DC? - are you really power constrained - battery? or is it a desktop/lab experimental apparatus
Hope these works for you
.SUBCKT IRF610 1 2 3
* Model Generated by MODPEX *
*Copyright(c) Symmetry Design Systems*
* All Rights Reserved *
* UNPUBLISHED LICENSED SOFTWARE *
* Contains Proprietary Information *
* Which is The Property of *
* SYMMETRY OR ITS LICENSORS *
*Commercial Use or Resale Restricted *
* by Symmetry License Agreement *
* Model generated on Sep 8, 97
* MODEL FORMAT: SPICE3
* Symmetry POWER MOS Model (Version 1.0)
* External Node Designations
* Node 1 -> Drain
* Node 2 -> Gate
* Node 3 -> Source
M1 9 7 8 8 MM L=100u W=100u
* Default values used in MM:
* The voltage-dependent capacitances are
* not included. Other default values are:
* RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0
.MODEL MM NMOS LEVEL=1 IS=1e-32
+VTO=4.20884 LAMBDA=0.00260948 KP=1.62458
+CGSO=1.31067e-06 CGDO=2.62913e-09
RS 8 3 0.422264
D1 3 1 MD
.MODEL MD D IS=1.48126e-09 RS=0.0584257 N=1.5 BV=300
+IBV=10 EG=1 XTI=2.86316 TT=1.21548e-07
+CJO=1.59766e-10 VJ=3.0125 M=0.648355 FC=0.5
RDS 3 1 1e+06
RD 9 1 0.668369
RG 2 7 8.25546
D2 4 5 MD1
* Default values used in MD1:
* RS=0 EG=1.11 XTI=3.0 TT=0
* BV=infinite IBV=1mA
.MODEL MD1 D IS=1e-32 N=50
+CJO=2.56674e-10 VJ=0.935001 M=0.877449 FC=1e-08
D3 0 5 MD2
* Default values used in MD2:
* EG=1.11 XTI=3.0 TT=0 CJO=0
.MODEL MD2 D IS=1e-10 N=0.4 RS=3e-06
RL 5 10 1
FI2 7 9 VFI2 -1
VFI2 4 0 0
EV16 10 0 9 7 1
CAP 11 10 4.53949e-10
FI1 7 9 VFI1 -1
VFI1 11 6 0
RCAP 6 10 1
D4 0 6 MD3
* Default values used in MD3:
* RS=0 BV=infinite IBV=1mA
.MODEL MD3 D IS=1e-10 N=0.4
.ENDS irf610
.SUBCKT IRF9610 1 2 3
* Node 1 -> Drain
* Node 2 -> Gate
* Node 3 -> Source
.MODEL MM PMOS LEVEL=1 IS=1e-32
+VTO=-3.56894 LAMBDA=2.66635e-07 KP=0.534832
+CGSO=1.5436e-06 CGDO=1.53305e-08
RS 8 3 0.221689
D1 1 3 MD
.MODEL MD D IS=5e-09 RS=0.01 N=1 BV=300
+IBV=10 EG=1.11 XTI=3 TT=6.6752e-10
+CJO=1.54088e-10 VJ=2.99942 M=0.80296 FC=0.5
RDS 3 1 1e+06
RD 9 1 1.8028
RG 2 7 2.18034
D2 5 4 MD1
+CJO=1.92701e-10 VJ=0.856605 M=0.783168 FC=1e-08
D3 5 0 MD2
RL 5 10 1
FI2 7 9 VFI2 -1
VFI2 4 0 0
EV16 10 0 9 7 1
CAP 11 10 2.99982e-10
FI1 7 9 VFI1 -1
VFI1 11 6 0
RCAP 6 10 1
D4 6 0 MD3
.ENDS irf9610
What kind of rails and trafo will you use?
Is it important that output is 100Vp?
What about rails on 100VDC and output 90Vp?
IRF710, IRF720, IRF740 are all 400VDS N-MOS devices.
It would be possible to build an N-Channel amplifier using them
and have rails +/-200 VDC
+/-200 is nothing to be afraid of. Tube people do it all the time.
I have made a circuit with IRF710, one 400VDS MOSFET.
As there is no such P-Channel device, it is a quasi push-pull with help of one BJT, 2SA1381. 2SA1381 is one 300Volt video transistor.
VAS, voltage amp stage is a bootstrap as we have no suitable P-Channel MOSFET for this.
We get one bootstrap N-Channel amplifier.
Upper -3dB is like 9 MHz. See diagram 1.
The amplifier at 200Vp-p output!!! gives only THD 0.002%
See diagram 2.
See diagram 2.
Made a circuit in SPICE. Is a correct language.
But this you understood, didnt you?
You are just out to tease. Why not comment on the circuit.
There must be a few details to critisize.
Every build of a circuit begins with exploring options.
My circuit is to help newvirus with ideas for a project.
And this is what posters should do.
How do I test the full power bandwidth?
I don't know how you generate a frequency sweep with your sim program.
Or you could try a number of frequencies at max power: 100K, 200K, 400K, etc and see when the amplitude begins to fall.
- Wide bandwidth class AB with 10mA quiescent?
