In our chat, Nelson mentions SIT Lite, which is a Tokin lightbulb amp. 🙂
Now that BAF and the ACA mini is put to bed, we can see some more
progress on these other fronts.
Thanks for the news Gentlemans
@ Diyers
Join the fun if not too late UNE RUDE Matched Pair (2pcs) de 2SK182ES (sans donnees) TOKIN Sit V-FET new old stock | eBay
Agreed and that being said, I don't think he's been sweating it much of late and rightfully so. 🙂Pa is biased quite hot 😀😀
As far as those bargain THF51s being fake - and the quantities alone would make one wonder - is anyone aware of other devices using that same case? My assumption is that this would be a difficult one to fake. Admittedly my knowledge of electronic exotica is nil.
Any idea of what that most expensive offering is - T0034? Any idea of what is different about that variant?
Those with devices who want to hear what they can do: ZM's SINGING BUSH is a very fine amplifier.
I would welcome something better but at the moment they have me in a blissful state and I cannot imagine anything being much better.
But much better would be welcomed. All things are possible when it comes to Mr,. Pass. (And then for ZM to finagle a little more in the design)
This is all great fun. We are lucky that our choice of entertainment involves one of the great entertainers of all time ...
for my needs, SissySIT is better
same case parts - I remember seeing somewhere around that there existed some bipolar transistors ..... or even triacs/thyristors ...... but I can't remember where exactly I've read that
I do not doubt that would be true for most.
In my case - no crossover and horn loading make the low damping factor amp superior - and my amps, each, are driving half of the frequency range does make my case unusual.
I should have mentioned that in my post.
I have no experience with back loaded horns but front loaded horns sound better with minimal damping from the amplifier.
only real experience can show which one is better for your ears, in your system
I've just said what's better in my case
I did not mean that to sound like I had compared SISSY and SB which you know very well have have not.
But I do know the difference between J2 on compression drivers and the MEH horn and it is decisive in my case. One would assume that the higher damping factor would always be better with woofers yet SB has the woofers in control without strangling them with unneeded damping, that is my conception of what is happening. Akin to finding a horn loudspeaker when using a conventional amplifier will usually sound better with resistance in between the amplifier and the speaker
Joining the VFET Party
Hi all - I’m crashing this party!
I just plunked down some coin on the matched quad THF51s Watanabe had for sale on eBay. It’s hard to justify the rapidly increasing cost of this rapidly dwindling resource, but this is entertainment, right?
Which way to the wine bar? 😀
Still cheaper than most 300B tubes. 🙂
You read my mind - as I commented to someone else, I am considering these the 300Bs of the solid state world.
The THF-51S is like an 845 in the solid state world, good for 50W output, but without the 1000V power supply. Definitely a good thing. 😀
My order from pras a few months ago never arrived for me... Thinking it's likely lost at this point. 🙁
Fortunately, I have a couple 182's for a Sissy build. I wonder if anyone has compared the two in the same circuit to see if there's any noticeably audible differences.
Works for me!
The big DHT like 211 and 845 in SE topology give output power max ~ 20Watts in class A ,
semiconductor Tokin triodes can produce more than twice
PRECISELY MATCHED QUAD (4PCS) de THF-51S (avec Curve Tracer des donnees) TOKIN Sit FET | eBay
Yes a lot cheaper, a matched pair of 300B made in USA from Western Electric cost ~ 1499 $
Quad cost 3099 $
Ok this ones are luxury 😀 not made in PRC copies
Original Western Electric 300B Vacuum Tube — Western Electric - Maker of electron tubes and high fidelity
Quad cost 3099 $
- While they last...
