What’s On the Bench Tonight (OBT)
One of the tests we used to do on new designs when I worked for DEC was AC line transient testing. I remember being recruited to operate some Schaffner generator, which would put ~4kV in differential and common mode. I had run the test before and always thought "this doesnt do anything". Then one day it did - nearly knocked me out of the chair by the bang that came out of the power supply.
The etch design had some pattern about a screw holding the PCB to the chassis. That pattern ended up looking like two points, aimed at one of the AC line traces running past. Apparently the field at the point tips became too intense as it arced over with a bang. They fixed it in the next etch spin.
Unsure if such testing is applicable to your AC line connected product, relative to something like a power supply for a VAX computer. I guess someone at DEC used to think such AC line transients really did happen out in the field and wanted the product to be impervious to it. Of course, back then they did lots of crazy testing - like SPRT estimation of MTBF - that no one these days can afford.
Reactions: xrk971
That's just a temporary chassis for set up and testing it'll get moved to two single cases.
SyncTronX: As an aside, I was at a garage sale and some guy was testing a drill -- he plugged it in and pulled the trigger, about 1 second after that a huge BANG with that electrical blue light (which was really kewl) followed by the cloud of smoke arose where the guy was testing. He through the drill down. he lived, it was an old two prong with aluminum case. I also think the guy was lucky to be alive, the garage circuit breaker didn't blow.
Hi Viet,
You probably missed my question in the other thread, so I'll repeat it here if I may:
What is the current consumption of the HyperSET (@230vac)? Just asking, because I would like to place the "final" fuse into the amp.
Now I use 2,5A because of the PSU, but maybe it's to much.
Many thanks in advance.
Cheers
Istvan
Sorry I missed the message Istvan.
I just performed a field test using a wall plug “wattometer” of a HyperSET with J&J E88CC tubes. 160mA peak at turn on and 110mA steady state at 120VAC. So about half that at 230VAC. This is using a SMPS AC/DC wallwart power adapter for the 12v.
So you need a tiny fuse of say 1.3x 80mA or circa 0.1A fuse should work. Might want a slow blow to prevent turn on transient from blowing it. Probably 0.2A fuse would be fine as well.
Reactions: Plott
I've always wanted a LM3886 based amplifier. So I got some cheap boards from China, possibly fake ICs, cheap wooden box and made mine.
The only thing that's great in this box is the transformer, a original 15-0-15 toroid.
It still sounds pretty decent!
Reactions: xrk971
@xrk971 Overall, the LM3886 is my third project that I "finished" per say... do we ever actually finish those?
I started it all with a PAM board, it was pretty bad overall, then I got a TPA3116 and delved deep into it, I still have my dual 3116 with your Snubber mod (been some years!)
There was also a TDA7377 which my FIL is currently using, and lastly this 3886. It took me a while to find a housing that would fit everything inside, aluminum chassis are pretty expensive where I live!
I ended up going with that board because it was the only one that somewhat resembled the boards made by Neurochrome. It really doesn't sound bad and it packs quite a bit of power considering I only feed it with 21-0-21v (that's the V output of that PSU).
It's alive!. It's now on the software development bench, where it is working as a 3-way without the shading or curvature. I should be able to reuse most of the code from the previous line array design to implement the electronic curvature and shading. It also needs dipole compensation since this is open baffle. The second one for stereo is still on the hardware bench. Putting the electronics on a hinged plate is working out well for development.
That’s a way cool project, Neil. Congrats on first sound!
On the bench tonight is a new coaxial speaker development I am starting. It’s an OEM design with a polycone woofer and a small compression driver with a small horn. The woofer has a nice magnet and sounds very smooth. Tweeter has nice upper end reach. Cabinet has usual perfect rosewood veneer and a slot vent reflex. I’ll be making measurements and developing a new crossover soon. This will be fun to see if I can make a time aligned single point source.
There’s a magnetically attached grill.
Reactions: YashN
