well, it needs to be organic, fair trade, cryogenically treated, linear crystal cotton to really make a difference 😀
don't we sometimes take ourselves just a bit too seriously?
along with the attitude that we should have a pill to fix everything.
We had few doctor choices on our medical insurance plan. Our doctor was a Jamaican educated at the British West Indies Medical Institute. Not a bad guy 25 years ago, but in the last few years I was in Florida he had convinced my wife that I was about to drop dead of a heart attack, and the cardiologist I was referred to had been deported back to Pakistan. I was taking 7 different prescription meds at a total out of pocket cost of nearly $3K per year. No job, no pills, no problem....so far. I have only turned blue once so far....about normal. I have failed 2 stress tests and turn blue occasionally. None of the medical experts I saw seems to why, but they are all willing to perform very expensive tests including a $22K cardiac catheterization .
Blondes driving M3, other 3-series BMW's on the New Jersey Turnpike
You forgot, while on the phone and applying make-up.
Use of the phrase "RMS power" to mean "average power".
Everybody knows that 120 W RMS means model # 120 With Real Mean Sound.....Or so said JC Whitney (remember them) when I explained which body orifice that amp belonged in.....my brother got a refund.
farding
What grinds my gears??? Not really trying to denigrate our "adopted" country...but here in Argentina it really is "different" & rather frustrating. Somewhere in Mid-June we had a "contractor" build us a car-port.....all fine & good, somewhat on time & seemingly well built (Still have to paint over the welds on the galvanized steel beams lest they rust-out). The guy, who fancies himself a fabricator, said he would build us a "salamandra", or a woodstove.....cool, we had a 5 Ft. high Natural gas tank (Well built via strict regulations) as a "foundation" to build with.....weeks go by as our "new room" freezes & is "uninhabitable from no heat......well, it is still "not done" & Summer is approaching. Our "new car-port" sprung a leak from the rain, the power line still wasn't re-routed for the lighting in the car-port....I have a makeshift routing for the lights as I shouldn't have to risk wrecking the roof from walking atop the thing...& not knowing just where I am 'suppose" to step. The new back-room has a space opened up for the MIA woodstove......still an empty spot.
There's a saying we've come up with, "Argentinian Time"......."I'll get to it whenever".......A mantra pervasive down here.
Case in point, there was a bad windstorm the other day...a 30 Ft "telephone pole"..(Eight inch diameter plain un-treated wood pole).....It was fully grown over with a vining plant, the roots were some four inches in diameter, all the way up, fully obscured, couldn't even see the "Pole". As it stands it was blown over...taking power lines & comm. lines with it. The power company reset the lines, guy wires & all were snapped, adjacent poles pulled at weird angles. It's been three days now, the coax cables are still at eye level, the poles still aren't straight, guy wires for the coax spiraled along here & there.......My guess is the guys said "Good enough"...........the rest of the job I'd guess is a Month or more off in the future.
------------------------------------------------Rick..........
Why cotton covered wire? Just nostalgia or something else?
To replace the rather dull and boring green/red/black/orange wires which I normally see inside all of my projects. Also a soft spot for 1910-1950s electronics. I don't know about you but I think the "Racecourse" R-Core transformers look rather steampunkish/1800s.
Secretly.. When the equipment is turned off I like to run my fingers along the wires. Cotton covered wire can add to that experience.
What would REALLY grease my gears is brass terminations on each end of the cotton tubes. Ohh yeahhh. Just like how you see heatshrink terminations on the end of computer power supply cables. Except with brass or copper.
But seriously I just want it to be personalised.
https://www.youtube.com/watch?v=wKX1KgIkBwg
I'm not the only crazy guy out there 🙂
This is for a TDA1541/TDA1543 Dual dac so its a vintage design anyway. a classic which I want to make look good AND sound good.
The difficult part is finding the cotton covering which goes over wire WITHOUT buying the actual wire inside, otherwise I have to buy the twisted stuff which is used for vintage fans and lamps.
I also like the fact that I can use a rigid copper strand and just put a bit of copper tubing over it and consider the wiring done. I don't want to do this for high voltage circuits just for low voltage stuff like you would find inside of a DAC. They did used to do this in tube amps though, they used to use a rigid wire to join two points inside of an amp and then just covered over it with cotton tube.
The search continues... I may have to just buy some lamp cord anyway and pull the good double insulated cable out of it but don't want to if I don't have to.
Like this ?
COTTON 1/4 BRAIDED EXPANDABLE SLEEVING COVERING WIRES MULTIPURPOSE TUBING | eBay
or
http://www.ebay.co.uk/itm/5-meters-...mponents_Supplies_ET&var=&hash=item4d1a0b1a3e
or
http://www.ebay.co.uk/itm/Single-Color-2MM-16MM-TIGHT-Braided-PET-Expandable-Sleeving/321452137104?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140122125356%26meid%3D93e169c26b28477aa264c2389ff475be%26pid%3D100005%26prg%3D20140122125356%26rk%3D2%26rkt%3D6%26sd%3D331149417022&rt=nc#ht_1734wt_946
or
or
BINGO Thanks heaps!
Tho that only shows one cotton type....
It doesn't show up for me over here! Grr...
You made my day 😀 I didn't know what it was called.
Braided Cotton Sleeve, Braided Cotton Sleeve Suppliers and Manufacturers at Alibaba.com
Now I do.
http://www.soundlabsgroup.com.au/c/Wire-Sleeving/Wire+-+Sleeving.html
I might have to buy that and dye it in a bucket to brown or black..
This is what I'm after (see attached picture) but not the wire inside.
A prepper does not expect the government to take care of everything, nor assumes experts to have the same goals.
We decide ourselves which retirement options to pick, which are the risks, do not count on the government to be reliable.
We do not put all our faith in banks, stock, or investment 'advisors'.
We do not place our faith in luck either, merely in odds at one given moment.
That's how my g/f wins at the casino four out of five visits, knows when to leave the fifth time (gambling addicted ho)
Amen. I read your other posts, it reminded me of the rules involved in driving a car around in my country: 🙄
https://www.youtube.com/watch?v=0wAhig3qSCE
Contracting stateside can be a problem, but the web pumps out a lot of good information on whom to avoid. Perhaps they need "Angie's List" down Argentine Way. (To put on a little addition to our house took 18 months.) I would have thought that currency would have been a bigger issue.
I think that contractors lead a feast-to-famine existence so they book a lot more than they can handle.
For solace read Peter Mayle's books about rehabbing a house in Provence.
This video shoved in my face whenever I open up youtube:
https://www.youtube.com/watch?v=b1XGPvbWn0A
She has a beautiful face and is wearing skin-tight fitting jeans with a skin-tight top and she has HUGE boobs. And she got mostly pleasant replies. What did she expect was going to happen?
30million views and enough money to "raise awareness" of the many men all around the world killing themselves every year because Women think and act like she does. Oh wait, no, that money is going to go towards furthering the stupidity.
When a woman acts completely closed off like this it is a recipe for disaster for boys who are already suicidal enough with the social pressures put on them.
Imagine (women) if you will what it would feel like to have Fabio treat you the exact same way as she has done. I'm sure women have nearly died over the sight of the Beatles. That is the exact same kind of effect wearing skin-tight clothing has on men. especially men who are treated like **** all the time by women just like this.
I agree that being stalked and chased or followed like one of the guys has done is utterly flat out wrong and borderline criminal. But the rest have acted rather appropriatley.
Being a pure and unadulterated Monster towards other men is no good for anyone.
Being so incredibly selfish as to want to tease men like this (and then not respond AT ALL) is PURE EVIL.
If a drop-dead HOT man done EXACTLY this and put on skimpy skin-tight clothing EXACTLY like this he would get EXACTLY the same response from Women.
What this video WONT show is that the back of her *** is SKIN TIGHT.
What this also DOESN'T tell you is that this 1:57minute long footage was taken from 10 HOURS OF FOOTAGE!!!
It took 10 hours to find just TWO men out of 5-6 who said something disagreeable to her.
https://www.youtube.com/watch?v=AdFxiaCvfyc
Mr Ellis, count your blessings in a city with inhabitants of mostly Spanish or Italian origin.
In other areas, mañana refers to tomorrow next year.
Very un-Europeanish to wet a beak, or grease the monkey.
(but not right before the start of Caribbean carnival, the Tumba festival, or any monday)
Dropping things!
As you watch it roll off the bench or slide into oblivion...NNNNNOOOOOO....NNNNNOOOTTTTT.....AAAGGAINNNN😱😱
As he takes a goalkeeper dive to save it.....NOOOOOOOOOOOO AARRRRRRGGGG...SMASH!!!!!!!
In the words of Forrest Gump..."and that's all I have to say about that!"
M. Gregg
M. Gregg
Freax,
The video doesn't say what she would think if nobody responded and nobody looked..😉
Imagine 10hrs of no response at all...If she talked to someone and they just passed the time of day..
However the guy walking alongside was a bit scary if you were a woman alone! (it would be worse in a lonely area)
M. Gregg
M. Gregg
Dropping things!
M. Gregg
Remind me to never sell you any of my circa-1920s vacuum tubes. 😛
Freax,
M. Gregg
Agreed this is pure troll material on her behalf.
And on the gullible Youtube community it was a piece of ****.
Yep if I was a girl and that happened to me I'd dig out the pepper spray/tazer and taze him till he sung the full verse of H.M.S Pinafore.However the guy walking alongside was a bit scary if you were a woman alone! (it would be worse in a lonely area)
https://www.youtube.com/watch?v=cQfJ8ZcpIAU
Right in the BALLLS!
Chat groups where people take exception to something I have said to deliberately flame the group.
- Someone has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
- Member Areas
- The Lounge
- What really grinds your gears?
