"WHAMMY" Pass DIY headphone amp guide
The inlet module is very nice!
Wire gauge required is more a function of length than anything else, if less than a foot 18ga or even 20ga would be fine. Use what you have, and you can always double it up if you are worried.
Complete - Sounds Great!
WHAMMY complete and sounds amazing! Thanks to everyone who worked on this project! Now on to the Aleph J...
thank you very much for the reply. unfortunately digikey and mouser are not providing free shipping unless i have spent enough in the place I live so that means i need to plan everything ahead.
This is a nice project, great presentation, and thorough documentation. Thanks to all who pulled it together!
I’ve a couple of questions:
Ever try an OP275 in the opamp position?
Can the opto-biased source follower stage operate stand-alone, without gain?
when introduced between source and amp circuit itself , pot is becoming source to amp
that means pot's own output impedance is thing in the game
lower , the better
in most critical position , Rout of pot is approx. 25% of it's nominal resistance , so better to have 2K5 as source Rout , than 25K
go figure
aha , one thing more - with 10K pot , interconnect cables are much less important players in game
All the units I built used the 100K Alps mostly because they are 10 meters away in the stock room. The TKD is pretty nice not sure I could tell the difference.
You can use a 10K with no value changes it would be less noise sensitive.
Almost complete, Need to tidy up some metal work, add a volume knob, and add a Headphone jack. Sounds very nice driving my A40. A big thanks to Wayne, 6L6, and alexcp (who sold me the board).
