replace bloody diodes across reg chips , replace opamps
prior to powering it up after repair , do not put opamp in socket , test rails first
While working on my Whammy I shorted something(s). I thought I had blown the regulators and the LEDs were off. I have replaced the regulators but the LEDs are still not on, and I am getting 30V on the regulator outputs and the opamp power pins. Can anyone point me to the best places to troubleshoot the problem ?
Sounds like open leds. The regulators have no ground reference. Zen Mods advice is good.
sorry Wayne , I wasn't clear enough - yes - replace all 4 diodes at regs - both 1N400x and both leds
Are there plans to restock the inventory of boards in the store?
There is plenty of inventory, you are just seeing the temporary changeover from one fulfillment center to the new one. Check back in a day or two.
Help !
Wayne, 6L6 and Zen Mod,
Thanks for the advice. I will order more diodes and change them out. Bizarrely with the 833 opamp and 30V it plays and sounds fine ! Not sure how long that would last though before it started smoking so it's out of use for now. Back to my £13 JLH 1969 🙂.
I have photos I can upload if anyone thinks it would add anything, but replacing all the diodes first makes sense.
Which LED ?
All,
I bought the Kingbright WP710A10LID LEDs in the BOM from Mouser with all the other bits. I can't order exact replacements because the postage will be ridiculous for such a small order. RS has lots of red Kingbright 3mm LEDs. What spec am I looking for please ? Forward voltage ? Reverse voltage ?
All,
All,
I have a some spare LEDs drop me a pm with your address and I will put them in the post for you Monday morning.
All,
just pull them from anything broken you have in drawers
or use green ones , if you have them new
if you change color (thus voltage across ) , change in both rails
Sorry if this was posted somewhere in the proceeding 47 pages. Does anyone have a digikey or Mouser bom they can share for this build? 🙂
What exactly is the purpose of R39/R40? The schematic shows that they along with the volume pot forming some type of voltage divider influencing the gain in some way.
In a early post I read where Jim stated that they "have all to do with oscillations" or something along those lines.
I just don't understand why they're needed.
Thanks.
Nobody can answer my question above about R39/R40??
LEDs & Diodes
JamieMcC
That's very kind of you, but I have already ordered some from RS with the diodes. Fortunately they don't have minimum order values anymore and reliably deliver next day - so the bits should be here on Monday.
I took the diodes out of the board ready for the new ones and tested them with my multimeter's diode testing function. I got 585 with red lead to the anode and infinite resistance with black lead to the anode, which I think means they are OK - so it looks like the LEDs have blown. Nevertheless I will replace them all as advised and see what happens.
JamieMcC
BOM
Nate,
There is a Mouser BOM in #5 of this thread, which I used. I have an Excel version I can dig out that you are welcome to a copy of tomorrow if that helps.
Nate,
They provide some real impedance to keep from oscillating in some situations. You may not need them.
Sounds like the safest bet is to go ahead and install them.
Thank you Wayne and Jim for your replies.
WHAMMY PCBs.
Jim, I still see "sold out" for the boards.😡
Any idea when this changeover from one fulfillment center to the other will be finalized and the boards will be available again?
Thanks.
Thanks.
At mouser there is an option to share the shopping basket - if you could share the link when you have found the correct parts that would be great 🙂PCB finally arrived. Now to decipher the BOM.
- "WHAMMY" Pass DIY headphone amp guide
