Wayne's BA 2018 linestage
Since the standoff is probably grounded, you also shorted the + rail to ground. It may not have hurt the circuit at all. Your issue may be the power supply.
...quick check would be to switch the power supply boards.
Thanks, Rick!
VRDN is "alone", but I have a spare second one I could try. [Ditched the dual-mono-fantasies]
If the standoff is grounded, there would be measurable continuity, not?
[And, when it's powered, touching the Aluminium-frame gives me that buzzing feeling...]
The numbers above have a mistake: R27 is 20.94 mV, seems good to me...
That's what my gut tells me the whole day...
Gotta snort into ZM's sleeve 😀 😀 😀
(in the end, it's something too banal to be true, like a disconnected wire touching something it shouldn't be touching, although there aren't many connected wires left)
If touching the case gives you a buzzing feeling when powered, yea, you have an issue. Measure the voltage from the case to the ground on the VRDN output. I bet you find your + rail voltage. The VRDN ground is not connected to earth ground unless you add a wire from VRDN output ground to the case.
Here's a little something. Might give you some SE ideas.
Reactions: myleftear
OK, I'm a moron, but in a classic tube amp build there is only one resistor creating a path to gound at the input. On this board that is R18 at 100k for CN2 and R39 at 100k for CN4. Adding in a pot it seems to operate with those resistors in parallel. Seems odd...
