Waveguides and horns
The sensitivity takes a big hit from the extra mass of the Aquaplas.
Standard application recommendation for optimum damping of diaphragm resonances is to cover the center 25%, as that is where amplitude is greatest.
If you wanted to get fancy you could effect constrained layer damping by adhering a small disk, or maybe two crossed strips for less mass, of aluminum foil to the center of the diaphragm.
First day of using Bruel Kjaer 2012 Audio Analyzer - setting up Mummy crossover (12BR70+D800Ti). I would like to contact anyone familiar with this nice machine.
Hi jzagaja
did you ever get a chance to listen and measure the B&C DCM50 with one of your horns?
i would be especially interested how it sounds and measures w/ the Iwata 300 ?
thanks
Not yet. We use BMS and Radian/Truextent.
jzagaja, was there any development re B&C DCM50 and your horns?
if you haven't had a chance, what would you recommend as the best horn from your production to extend a lower end as much as possible (recommended by B&C is 400hz but i would love at least 350hz with few watts...) while having clean dispersion without beaming or other nasty artefacts.
also i can't find more comments on your minphase 200 horn, the price is much more affordable than JMLC and it looks like it has a very similar lip-over. how does it behave in the mids?
are there any plans for really big OSWG, like 18" or similar? since i've heard geddes OSWG (from summa), i think it's a way to go in smaller rooms....
Today I've learned how to store graphs in BK2012. This is quite easy - you have to chose plotter as output device, then open in ABViewer for example and format. Quick and dirty comparison between 12BR70+D800Ti vs. 12B100R+DE500. Level was quite low a bit below 1Vrms but I couldn't set more because of family members. I'm sending Mummy 4 (12BR70+D800Ti) with minimalistic crossover to Lukasz for voicing, attaching Aquaplased diaphragms.
Pink is 12B100R :)
