I've used : https://www.futurlec.com/ for boards
(Based in Thailand)
Fast, efficient, affordable and Competent. Try them?
(Based in Thailand)
This is the company I have been using for PCB manufacturing. Printed Circuit Board - PCBs in 24 Hours.
The boards are well made and the best price I have found. It does take around three weeks to receive them using Sweden post, ( their cheapest option for shipping to the states.) The only drawback is that they require bundles of 5 boards, so I always buy 10 so I have equal pairs.
As promised, here's my revised design to accomodate the 10uf MKP input bypass cap, I'm not so sure if the gerber files are correctly generated as I have never tried it before. It also inludes pdf files for home etching ..Sir Jean, I was too late to see your post but I'll see if I can work on the files again, but the polarized e-lytic works excellent as well. 😉 I use Sprint, I prefer direct draw approach it works for me
In my current state I can't start a group buy, sorry guys but I'll see if one of my friends could help me out with the job. 🙁
Thank you guys for the input.
Best regards!
Best regards!
Whooops, didn't realize gbr and rar files is invalid, I added a .txt extension to each gbr files, just delete the .txt extension.
Hope it helps!
Hope it helps!
Hi Abetir,
Just finished my new PCB for it 😀
Beautiful!
Looks like a furious ancient spirit's face.
Congratulations,
M.
Oh man, just when I thought I had built my last Peeceebee. 😱
Going to have to at least etch a pair. 😀
Terry,you catched a virus😀
Yves.....a really big and strong one ........a real pleasure ho see.......
Marc
Congratulations!Hi Abetir,
Where is PDF?🙂
Marc
S...t cross finger => Yes.....a really big and strong one ........a real pleasure to see.......
Marc
Nice observation dude, Nice to see again, you became one of my inspirer men in this last time at electronic diyaudio and music.
The pdf
Ok, this some file...
yes the curves look a bit scary isn't it 😱 😀
(I hope nobody scared, no pun intended)
I'm just happing fun to create it 🙂
Thanks ,beautiful curves 😉Ok, this some file...
You must post the schematic diagram also🙂🙂
Thanks, Dadi.
How is your own VSSA going?
M.
PS: good luck tomorrow...I can't say which team we are going to support...auf wiedersehen, hehe.
I finish in build one, its sound good with one power supply I had later i gota connexant but when Connect it blow up instantaneously. I sent the SMPS to the origin, cause they promise in repair, a soon I shipped it they return the payment and propose to get a new.
Summarizing, I lost time and money. BTW i am getting the parts for a Vfet complementary schema from NP. I trying with a SE with Vfet and a 211 in ongaku circuit. While the VSSA is sleeping in the closet.
Thanks for the luck for tomorrow, Chile played fantastically with Brazil, sadly collapses in the complementary, but Brazil lost the energy in this tremendous match and repeat the epic against Colombia and for this reason lost with Germany with a disastrous 7-1
The best for you Mauricio querido.
Yeah, we played like never, we lost like always... 🙁
Maybe next cup will avoid penalty kicks and go for "first goal wins all" ("muere-muere") in the complimentary, like in the "barrio". 😀
Sorry to hear about your bad experience. I bought some SMPS but never used them: still prefer a linear PS with "charge-transfer" circuit. I'll probably build some SMPS based amp for the children... 🙂 like BJT-VSSA which is rugged.
M.
M.
- VSSA Through-Hole-PCB build thread
