Valve Itch phono
Hi Salas,
The Riaa components values have been tested both by measurement and subjective tone. Silver Mica bypassed PP is used for the 100nF, K72 33nF Teflon + 2200pF Siver Mica for the 35.2nF.
Aren't those Russian K72 capacitors magnetic?
… Mogami thin shielded coax for signal. …
Do you mean the Mogami microphone cable?
Where do you connect the shield, do you connect it at both ends?
This is revision 1.2
Audio circuit rework. Mainly values.
Subjective impressions are enhanced vs. older version realizations.
Also you added on version 1.2 a LED at the cathode of V1.
I believe it's intended to eliminate any small voltage on the grid of V1. Am I correct here? Or was it added also for improving the subjective impressions?
diyAudio Chief Moderator
Joined 2002
ΙR LED. Not all SUTs can take a little grid current happily through their secondary and its also safe for direct MM without handpicking 6N2P-EVs for super minimum grid current. Allows to primarily pick for channel match and low noise. Does good to THD also.
Mogami has a range of nice single core non XLR coaxials too. Both ends to gnd.
They are steel cased caps, yes.
