I cannot find HIRL5020 at a reasonable price
Why this specific one? Btw I sampled some different 5-6 IR leds the other day. Quite a large difference in Vf drop, up to some 40% if I remember correctly. Also one has to make sure its stable down to half a milliamp or so. Not everyone are.
Thank you.
Because of it was mentioned by Salas.
Was they different part numbers, or different specimens of the same part number?
Thank you.
Was they different part numbers?
Yes. I did not test linearity and low current ability though. Between 1.1 and 1.6 in drop or so if I remember right at some 5-10 mA.
Thank you.
What part numbers are good?
Didnt write it down. Can maybe redo it when I have the time. Testing with a 9 V and 10 k would be relevant for this application I guess.
A really interesting shootout would be to compare noice between different IR-leds and different rectifyer diodes in this application. Under 1 V bias would give a beneficial kick to the pre-stage driving the compensation filter.
Yes, but then I have to order few part numbers and check each one. It will help me knowing what part numbers are good, before purchasing.
Concerning the IR LED
The HIRL5020 recommended by Salas in unobtanium. It's rated 100mA forward voltage and 1.45-1.7 forward voltage.
There are other LEDS with similar specs stocked and there are LEDS with better-looking specs, rated 100mA 1.2V, 50mA 1.2V and 20mA 1.2V.
Before ordering many part numbers with various specs, which ones should I buy in order to test them?
The specifications from the manufacturers are often not consistant, for example Vf is not at a standardised current so it takes some figuring out in the datasheets and also testing to figure out.
If I have the time some day I will do the ones I have at 0,5, 1,0 and 1,5mA so we can se Vf drop and linearity at those currents.
You dont need 100 mA.
I did FYI a quick and dirty on one sample yesterday. Family wanted me elsewhere so I only had time for that, we'll see if I can sneak away quick in the weekend to do some more samples.
The test setup was bench supply plus side - one matched 10 k resistor - IR LED - bench supply minus. One DMM over the 10 k resistor and another over the LED.
To get 1,5 mA over the LED I adjusted the bench supply until I had 15,00 Vdc over the 10 k resistor. Then I did 1,0 mA same way, 10 V over the resistor and then 0,5 mA, ie 5 V.
I wrote down values over LED to test low current stability and linearity. The first and only I ran, dont remember brand or number now, was stable at all values and varied some tens or hundreds of microamps so it seemed fairly linear. Yesterday I found only two different brands, I have some more somewhere.
Vf drop values was somewhere between 1,0-1,1 V, forgot the note at home. Brb with more samples later. Cheers.
Right Joshua_G, heres some samples:
First out 3 samples of HIR7373B/L289 from Everlight Electronics
https://www1.elfa.se/data1/wwwroot/assets/datasheets/HIR7373B-L289_eng_tds.pdf
0,5 mA: 1,240 V 1,248 V 1,236 V
1,0 mA: 1,267 V 1,271 V 1,264 V
1,5 mA: 1,282 V 1,283 V 1,280 V
Linear and consistant but fairly high drop.
Then some IR 333/S2 from the same firm:
https://www1.elfa.se/data1/wwwroot/assets/datasheets/07522519.pdf
0,5 mA: 1,027 V 1,028 V 1,040 V
1,0 mA: 1,054 V 1,056 V 1,069 V
1,5 mA: 1,066 V 1,072 V 1,085 V
Also linear but much better Vf drop for this app.
And then some 1N4148 for fun:
https://www1.elfa.se/data1/wwwroot/assets/datasheets/DIOTEC_1n4148_eng_tds.pdf
0,5 mA: 0,578 V 0,577 V 0,578 V
1,0 mA: 0,611 V 0,611 V 0,611 V
1,5 mA: 0,632 V 0,633 V 0,631 V
How about that for consistency? Pretty linear to.
Well, the IR 333/S2 seems like a good choice for a LED if you can get it. I'd try the 1N4148 and maesure THD on the whole application and see if there is a noticable differance.
The current values is choosen for different 6N2PEV samples you might get your hands on.
Thank you very much.
Both part numbers are available at Mouser. I just ordered some HIR323CH0 ones.
What is the out Z of the 6n2p mu-follower?
Only 1 ohm?
Is for calculate the RIAA network.
Only 1 ohm?
The top section of a μ-follower is a buffer beyond a CCS.
Zo=Rp/(μ+1)
*Rp=internal plate resistance spec, μ=gain spec of the specific tube type.
Zo=Rp/(μ+1)
- Analogue Source
- Valve Itch phono
