I'll move them to the spice tube models thread that way they will not disappear.
Edit: Moved
Ok, thanks
The question came up on LTSpice, so I worked the optimization for the Svetlana SV811 -- the RCA datasheet only has positive Vg values:
.subckt SV811 1 2 3
+Params: MU=8.839 KP=91.39 KVB=1437 EX=1.301 KG1=2486
E1 7 0 Value = {(V(1,3)/KP)*LN((1+ EXP((KP/MU) + ((KP*(V(2,3)+.5))/(SQRT(KVB+V(1,3)*V(1,3)))))))}
RE1 7 0 1e12
G1 1 3 VALUE = {(((V(7))^EX)/KG1)*(1+SGN(V(7)))}
RCP 1 3 1e12
C1 2 3 6e-12
C2 1 2 6e-12
C3 1 3 0.7e-12
R1 2 5 2000
D3 5 3 dx
.model dx d(is=1e-09 rs=1 cjo=10e-12)
.ends
.subckt SV811 1 2 3
RE1 7 0 1e12
RCP 1 3 1e12
C1 2 3 6e-12
C2 1 2 6e-12
C3 1 3 0.7e-12
R1 2 5 2000
D3 5 3 dx
.ends
Can somebody find the reason why this model does not work with LTspice ?
.SUBCKT 6P13S-t 1 2 3 ; P G C (Triode) 27-Nov-2007
+ PARAMS: MU= 9.51 EX= 1.26 KG1=686 KP=91.81
+ KVB=8430 VCT=0.00 RGI=1000
+ CCG=18.5P CGP=0.5P CCP=6.5 <======== p(ico) missing !
E1 7 0 VALUE=
+{V(1,3)/KP*LN(1+EXP(KP*(1/MU+(V(2,3)+VCT)/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G ; TO AVOID FLOATING NODES IN MU-FOLLOWER
C1 2 3 {CCG} ; CATHODE-GRID;
C2 2 1 {CGP} ; GRID-PLATE;
C3 1 3 {CCP} ; CATHODE-PLATE;
D3 5 3 DX ; FOR GRID CURRENT
R1 2 5 {RGI} ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
the reason why it doesn't work for AC sim is because CCP is given as 6.5 Farad (instead of pico). ........
After 4 iterations and debugging of the Extract Model tool by Derk, I managed to refine the 6e5p beam tetrode model:
The valve saturates massively above 50mA so hence the gap with the model at low Vg values. Not an issue as will never be used at these levels.
Here are the details 6e5p beam tetrode SPICE model | Bartola Valves
Ale
Ale
6267, EF86 equivalent.
Code:
* Generic pentode model: 6267
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Sat Mar 8 22:42:16 2008
* Plate
* | Screen Grid
* | | Control Grid
* | | | Cathode
.SUBCKT 6267_AN A G2 G1 K
BGG GG 0 V=V(G1,K)+0.59868749
BM1 M1 0 V=(0.010782364*(LIMIT(V(G2,K),0,1e16)+1e-10))^-0.70765893
BM2 M2 0 V=(0.67945278*(LIMIT((V(GG)+LIMIT(V(G2,K),0,1e16)/29.728844),0,1e16)))^2.2076589
BP P 0 V=0.0013378994*(LIMIT((V(GG)+LIMIT(V(G2,K),0,1e16)/43.754099),0,1e16))^1.5
BIK IK 0 V=STP(V(GG))*V(P)+(1-STP(V(GG)))*0.00078620809*V(M1)*V(M2)
BIG IG 0 V=0.00066894969*LIMIT(V(G1,K),0,1e16)^1.5*(LIMIT(V(G1,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+LIMIT(V(G1,K),0,1e16))*1.2+0.4)
BIK2 IK2 0 V=V(IK,IG)*(1-0.4*(EXP(-LIMIT(V(A,K),0,1e16)/LIMIT(V(G2,K),0,1e16)*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.83966688*(1-LIMIT(V(A,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+10))^1.5+0.16033312)
BIK3 IK3 0 V=V(IK2)*(LIMIT(V(A,K),0,1e16)+7510)/(LIMIT(V(G2,K),0,1e16)+7510)
BIK4 IK4 0 V=V(IK3)-LIMIT(V(IK3)-(0.00071507731*(LIMIT(V(A,K),0,1e16)+LIMIT(LIMIT(V(G2,K),0,1e16)-LIMIT(V(A,K),0,1e16),0,1e16))^1.5),0,1e16)
BIP IP 0 V=LIMIT(V(IK4,IG2T)-LIMIT(V(IK4,IG2T)-(0.00071507731*LIMIT(V(A,K),0,1e16)^1.5),0,1e16),0,1e16)
BIAK A K I=V(IP)+1e-10*V(A,K)
BIG2 G2 K I=LIMIT(V(IK4,IP),0,1e16)
BIGK G1 K I=V(IG)
* CAPS
CGA G1 A 0.05p
CGK G1 K 2.3p
C12 G1 G2 1.5p
CAK A K 5.3p
.ENDS
Does anyone have a Spice model for the 1J6 or type 19? I think these tubes are equialent.
I tried to create a model for the 19/1J6 using the model paint kit. It probably isn't spectacular since it is my first such model, but I'll post the model here for review.
Was I even close?
Code:
**** 1J6G ******************************************
* Created on 02/06/2014 18:34 using paint_kit.jar 2.9
* www.dmitrynizh.com/tubeparams_image.htm
* Plate Curves image file: 1j6.jpg
* Data source link:
.SUBCKT TRIODE_1J6G 1 2 3 ; Plate Grid Cathode
+ PARAMS: CCG=3.2P CGP=7.5P CCP=4.4P RGI=2000
+ MU=18.8 KG1=5460 KP=120 KVB=156 VCT=4.395E-6 EX=1.41
* Vp_MAX=200 Ip_MAX=40 Vg_step=5 Vg_start=25 Vg_count=7
* Rp=4000 Vg_ac=55 P_max=1 Vg_qui=-48 Vp_qui=300
* X_MIN=56 Y_MIN=49 X_SIZE=828 Y_SIZE=663 FSZ_X=1412 FSZ_Y=807 XYGrid=false
* showLoadLine=n showIp=y isDHT=n isPP=n isAsymPP=n showDissipLimit=y
* showIg1=n gridLevel2=n isInputSnapped=n
* XYProjections=n harmonicPlot=n harmonics=y
E1 7 0 VALUE={V(1,3)/KP*LOG(1+EXP(KP*(1/MU+(VCT+V(2,3))/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G ; TO AVOID FLOATING NODES
C2 2 1 {CGP} ; GRID=PLATE
D3 5 3 DX ; POSITIVE GRID CURRENT
R1 2 5 {RGI} ; POSITIVE GRID CURRENT
.ENDS
Code:* * Generic pentode model: 6267 * Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved. * Version 3.10, Generated on Sat Mar 8 22:42:16 2008 * Plate * | Screen Grid * | | Control Grid * | | | Cathode * | | | | .SUBCKT 6267_AN A G2 G1 K BGG GG 0 V=V(G1,K)+0.59868749 BM1 M1 0 V=(0.010782364*(LIMIT(V(G2,K),0,1e16)+1e-10))^-0.70765893 BM2 M2 0 V=(0.67945278*(LIMIT((V(GG)+LIMIT(V(G2,K),0,1e16)/29.728844),0,1e16)))^2.2076589 BP P 0 V=0.0013378994*(LIMIT((V(GG)+LIMIT(V(G2,K),0,1e16)/43.754099),0,1e16))^1.5 BIK IK 0 V=STP(V(GG))*V(P)+(1-STP(V(GG)))*0.00078620809*V(M1)*V(M2) BIG IG 0 V=0.00066894969*LIMIT(V(G1,K),0,1e16)^1.5*(LIMIT(V(G1,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+LIMIT(V(G1,K),0,1e16))*1.2+0.4) BIK2 IK2 0 V=V(IK,IG)*(1-0.4*(EXP(-LIMIT(V(A,K),0,1e16)/LIMIT(V(G2,K),0,1e16)*15)-EXP(-15))) BIG2T IG2T 0 V=V(IK2)*(0.83966688*(1-LIMIT(V(A,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+10))^1.5+0.16033312) BIK3 IK3 0 V=V(IK2)*(LIMIT(V(A,K),0,1e16)+7510)/(LIMIT(V(G2,K),0,1e16)+7510) BIK4 IK4 0 V=V(IK3)-LIMIT(V(IK3)-(0.00071507731*(LIMIT(V(A,K),0,1e16)+LIMIT(LIMIT(V(G2,K),0,1e16)-LIMIT(V(A,K),0,1e16),0,1e16))^1.5),0,1e16) BIP IP 0 V=LIMIT(V(IK4,IG2T)-LIMIT(V(IK4,IG2T)-(0.00071507731*LIMIT(V(A,K),0,1e16)^1.5),0,1e16),0,1e16) BIAK A K I=V(IP)+1e-10*V(A,K) BIG2 G2 K I=LIMIT(V(IK4,IP),0,1e16) BIGK G1 K I=V(IG) * CAPS CGA G1 A 0.05p CGK G1 K 2.3p C12 G1 G2 1.5p CAK A K 5.3p .ENDS
I get an error in Tina - "line 16, invalid function LIMIT"
I think there's supposed to be a parentheses in front but I still get the error.
It's the incorrect version of the code. TINA uses the URAMP, not the LIMIT function... Try this one:
Code:
* Copyright 2003--2006 by Ayumi Nakabayashi, All rights reserved.
* Version 3.01, Generated on Wed Mar 22 17:22:56 2006
.SUBCKT 6267 A G2 G1 K
BEP EP 0 V=URAMP(V(A,K))+1e-10
BEG EG 0 V=URAMP(V(G1,K))+1e-10
BEG2 EG2 0 V=URAMP(V(G2,K))+1e-10
BM1 M1 0 V=(0.010782364*(URAMP(V(EG2)-1e-10)+1e-10))^-0.70765893
BM2 M2 0 V=(0.67945278*(URAMP(V(GG)+V(EG2)/29.728844)+1e-10))^2.2076589
BP P 0 V=0.0013378994*(URAMP(V(GG)+V(EG2)/43.754099)+1e-10)^1.5
BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.00078620809*V(M1)*V(M2)
BIG IG 0 V=0.00066894969*V(EG)^1.5*(V(EG)/(V(EP)+V(EG))*1.2+0.4)
BIK2 IK2 0 V=V(IK,IG)*(1-0.4*(EXP(-V(EP)/V(EG2)*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.83966688*(1-V(EP)/(V(EP)+10))^1.5+0.16033312)
BIK3 IK3 0 V=V(IK2)*(V(EP)+7510)/(V(EG2)+7510)
BIK4 IK4 0 V=V(IK3)-URAMP(V(IK3)-(0.00071507731*(V(EP)+URAMP(V(EG2,EP)))^1.5))
BIP IP 0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.00071507731*V(EP)^1.5)))
BIG2 G2 K I=URAMP(V(IK4,IP))
BIGK G1 K I=V(IG)
* CAPS
CGA G1 A 0.05p
CGK G1 K 2.3p
C12 G1 G2 1.5p
CAK A K 5.3p
.ENDS
Was I even close?
I don't think so, you can check the results with this asc file.
Parts look fairly close... Although there is considerable error when the grid gets above 15.
Could you please post a picture? Is this datasheet used for the model?
Not true. TINA understands 'LIMIT' (PSpice) just fine. Since Micro-Cap understands PSpice and 3f4 spice with the limit function, I got lazy and posted a 6267 model that works in Micro-Cap, but was not in a true PSpice format. My bad... So here is a 6267 PSpice model:It's the incorrect version of the code. TINA uses the URAMP, not the LIMIT function...
Code:
* Plate
* | Screen Grid
* | | Control Grid
* | | | Cathode
.SUBCKT 6267_AN2 A G2 G1 K
EGG GG 0 VALUE={V(G1,K)+0.59868749}
EM1 M1 0 VALUE={(0.010782364*(LIMIT(V(G2,K),0,1e16)+1e-10))^-0.70765893}
EM2 M2 0 VALUE={(0.67945278*(LIMIT((V(GG)+LIMIT(V(G2,K),0,1e16)/29.728844),0,1e16)))^2.2076589}
EP P 0 VALUE={0.0013378994*(LIMIT((V(GG)+LIMIT(V(G2,K),0,1e16)/43.754099),0,1e16))^1.5}
EIK IK 0 VALUE={STP(V(GG))*V(P)+(1-STP(V(GG)))*0.00078620809*V(M1)*V(M2)}
EIG IG 0 VALUE={0.00066894969*LIMIT(V(G1,K),0,1e16)^1.5*(LIMIT(V(G1,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+LIMIT(V(G1,K),0,1e16))*1.2+0.4)}
EIK2 IK2 0 VALUE={V(IK,IG)*(1-0.4*(EXP(-LIMIT(V(A,K),0,1e16)/LIMIT(V(G2,K),0,1e16)*15)-EXP(-15)))}
EIG2T IG2T 0 VALUE={V(IK2)*(0.83966688*(1-LIMIT(V(A,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+10))^1.5+0.16033312)}
EIK3 IK3 0 VALUE={V(IK2)*(LIMIT(V(A,K),0,1e16)+7510)/(LIMIT(V(G2,K),0,1e16)+7510)}
EIK4 IK4 0 VALUE={V(IK3)-LIMIT(V(IK3)-(0.00071507731*(LIMIT(V(A,K),0,1e16)+LIMIT(LIMIT(V(G2,K),0,1e16)-LIMIT(V(A,K),0,1e16),0,1e16))^1.5),0,1e16)}
EIP IP 0 VALUE={LIMIT(V(IK4,IG2T)-LIMIT(V(IK4,IG2T)-(0.00071507731*LIMIT(V(A,K),0,1e16)^1.5),0,1e16),0,1e16)}
GIAK A K VALUE={V(IP)+1e-10*V(A,K)}
GIG2 G2 K VALUE={LIMIT(V(IK4,IP),0,1e16)}
GIGK G1 K VALUE={V(IG)}
* CAPS
CGA G1 A 0.05p
CGK G1 K 2.3p
C12 G1 G2 1.5p
CAK A K 5.3p
.ENDS
Ok, that's good to know, not that I want to use TINA.
- Tubes / Valves
- Vacuum Tube SPICE Models
