Sorry about that. I replaced the symbol file with a generic one, "Diode_Valve.asy". I've also added a directly heated half-wave rectifier symbol. You can copy those to your .../lib/sym directory.Sorry,
it does not work. The Symbol Need the tube.lib file. This is not in my System. Is there another model out?
Thanks for Help
Dieter
I have attached the corrected zip file below:
I am looking for LTSpice model (triode connected) E55L/8233.
Hi euro21,
This model works in LT spice.
Best diying.
.subckt e55l p g k ;Rydel's Models Triode Mode
+params: gp=0.004735979219 b=3734.604234
+ c=0.3266713215 d=79.54627249
+ cgk=11p cgp=5p
+ cpk=1.8p mu=30
e1 1 0 value= {1+(v(g,k)/b)}
re1 1 0 100meg
e2 2 0 value= {v(p,k)/(v(p,k)+c)}
re2 2 0 100meg
e3 3 0 value= {v(g,k)+((v(p,k)+d)/mu)}
re3 3 0 100meg
g1 p k value= {gp*v(1)*v(2)*(pwr(v(3),1.5)+pwrs(v(3),1.5))}
rpk p k 100meg
c1 g k {cgk}
c2 g p {cgp}
c3 p k {cpk}
.ends
6KY8A triode section model for LTspice.
Code:* 6KY8AT LTSpice model * Rydel model (5 parameters): mean fit error 0.150746mA * Traced by Wayne Clay on 6/22/2015 using Engauge Digitizer and * Curve Captor v0.9.1 from RCA datasheet. .subckt 6KY8AT P G K Bp P K I= + ((0.00144469087m)+(-0.0001050179892m)*V(G,K))*uramp((71.84993107)* + V(G,K)+V(P,K)+(62.44961062))**1.5 * V(P,K)/(V(P,K)+(3.613380107)) Cgk G K 15.2p ; 0.2p added (15p, K+H) Cpk P K 7.2p ; 0.2p added (7.0p, K+H) Cgp G P 1.14p ; 0.7p added (0.44p) Rpk P K 1G ; to avoid floating nodes d3 G K dx1 .model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n) .ends 6KY8AT
Hi cogsncogs, thank you very much for you time to create a LTSpice model of 6KY8A triode section! 🙂
Hi euro21,
Best diying.
Thanks, I will try.
Here's a 5879, in LTSpice format:
Code:
* Generic pentode model: 5879
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Tue Jul 14 16:35:33 2015
* Plate
* | Screen Grid
* | | Control Grid
* | | | Cathode
.SUBCKT 5879 A G2 G1 K
BGG GG 0 V=V(G1,K)+0.73732476
BM1 M1 0 V=(0.034464412*(URAMP(V(G2,K))+1e-10))**-1.4485185
BM2 M2 0 V=(0.50873007*(URAMP(V(GG)+URAMP(V(G2,K))/14.254412)))**2.9485185
BP P 0 V=0.0009600466*(URAMP(V(GG)+URAMP(V(G2,K))/28.019598))**1.5
BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.00091268793*V(M1)*V(M2)
BIG IG 0 V=0.0004800233*URAMP(V(G1,K))**1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4)
BIK2 IK2 0 V=V(IK,IG)*(1-0.4*(EXP(-URAMP(V(A,K))/URAMP(V(G2,K))*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.82440021*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))**1.5+0.17559979)
BIK3 IK3 0 V=V(IK2)*(URAMP(V(A,K))+5300)/(URAMP(V(G2,K))+5300)
BIK4 IK4 0 V=V(IK3)-URAMP(V(IK3)-(0.00053187427*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))**1.5))
BIP IP 0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.00053187427*URAMP(V(A,K))**1.5)))
BIAK A K I=V(IP)+1e-10*V(A,K)
BIG2 G2 K I=URAMP(V(IK4,IP))
BIGK G1 K I=V(IG)
* CAPS
CGA G1 A 0.11p
CGK G1 K 1.6p
C12 G1 G2 1.1p
CAK A K 2.4p
.ENDS
And here's the triode version:
Code:
* Generic triode model: 5879T
* Version 3.10, Generated on Tue Jul 14 16:48:12 2015
* Plate
* | Grid
* | | Cathode
.SUBCKT 5879T A G K
BGG GG 0 V=V(G,K)+0.73732476
BM1 M1 0 V=(0.034464412*(URAMP(V(A,K))+1e-10))**-1.4485185
BM2 M2 0 V=(0.50873007*(URAMP(V(GG)+URAMP(V(A,K))/14.254412)+1e-10))**2.9485185
BP P 0 V=0.0009600466*(URAMP(V(GG)+URAMP(V(A,K))/28.019598)+1e-10)**1.5
BIG IG 0 V=0.0004800233*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK A K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.00053187427*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK G K I=V(IG)
* CAPS
CGA G A 1.4p
CGK G K 1.4p
CAK A K 0.8p
.ENDS
12BY7 Full Pentode Model
Hi, folks !
Anyone have 12BY7(A) LTSpice full pentode model?
There are 12BY7A model on this thread, and another by S.Bench, both have suppressor grid connected to tetrode.
Thanks in advance.
Hi, folks !
Thanks in advance.
Since there isn't any data given for the suppressor grid, how do you build a model, and for what purpose?There are 12BY7A model on this thread, and another by S.Bench, both have suppressor grid connected to tetrode.
Great thread, guys. I just read the whole thing and look forward to trying out the models that I have found.
In the spirit of giving back, here is a zip file with all the models in the thread. They are all in LTspice format (although I may have overlooked something along the way). Each model is in its own file. Just extract it to the directory c:\Program Files\LTC\LTspiceIV\lib\sub (or ~/.wine/drive_c/Program Files/LTC/LTspiceIV/lib/sub for the Linuxheads like me, hehehe) and have fun.
6AV5 SPICE Models
6AV5 Triode-Connected:
6AV5 Pentode
Code:
* Generic triode model: 6AV5_T_AN
* Version 3.10, Generated on Sat Aug 08 06:58:28 2015
* Plate
* | Grid
* | | Cathode
.SUBCKT 6AV5_T_AN A G K
BGG GG 0 V=V(G,K)+-0.29077469
BM1 M1 0 V=(0.18958966*(URAMP(V(A,K))+1e-10))**-1.6704161
BM2 M2 0 V=(0.47312401*(URAMP(V(GG)+URAMP(V(A,K))/2.7790334)+1e-10))**3.1704161
BP P 0 V=0.0023638086*(URAMP(V(GG)+URAMP(V(A,K))/5.8737948)+1e-10)**1.5
BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.002829284*V(M1)*V(M2)
BIG IG 0 V=0.0011819043*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK A K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0018105601*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK G K I=V(IG)
* CAPS
CGA G A 0.5p
CGK G K 14p
CAK A K 7p
.ENDS
6AV5 Pentode
Code:
* Generic pentode model: 6AV5_AN
* Version 3.10, Generated on Sat Apr 11 09:38:05 2015
* Plate
* | Screen Grid
* | | Control Grid
* | | | Cathode
.SUBCKT 6AV5_AN A G2 G1 K
BGG GG 0 V=V(G1,K)+-0.29077469
BM1 M1 0 V=(0.18958966*(URAMP(V(G2,K))+1e-10))**-1.6704161
BM2 M2 0 V=(0.47312401*(URAMP(V(GG)+URAMP(V(G2,K))/2.7790334)))**3.1704161
BP P 0 V=0.0023638086*(URAMP(V(GG)+URAMP(V(G2,K))/5.8737948))**1.5
BIG IG 0 V=0.0011819043*URAMP(V(G1,K))**1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4)
BIG2T IG2T 0 V=V(IK2)*(0.96749811*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))**1.5+0.03250189)
BIK3 IK3 0 V=V(IK2)*(URAMP(V(A,K))+2055)/(URAMP(V(G2,K))+2055)
BIK4 IK4 0 V=V(IK3)-URAMP(V(IK3)-(0.0018105601*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))**1.5))
BIP IP 0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.0018105601*URAMP(V(A,K))**1.5)))
BIGK G1 K I=V(IG)
* CAPS
CGA G1 A 0.5p
CGK G1 K 8.4p
C12 G1 G2 5.6p
CAK A K 7p
.ENDS
Excellent, thanks very much!
One question -- Which version of 6AV5 is the model based on? 6AV5GA? Also, which brand's data was used? Sylvania? GE? RCA? Other? There's been much discussion on the relative robustness and performance of different versions of this particular tube. Tubelab has posted about varying dissipation limits between versions. I'm not sure if that impacts characteristics that would affect the spice model...
thanks again for this.
You are welcome, the model is based on the GE datasheet which is pretty much the same as the others. If someone can trace some triode curves for the more robust ones, I can make a model for it.Which version of 6AV5 is the model based on? 6AV5GA? Also, which brand's data was used? Sylvania? GE? RCA? Other?
looking for this schematic in ltspice, hope not asking too much. thank you
There is nothing special about the design, it uses all standard tubes which are available from this thread and elsewhere.
I will search again and see if anything new turns up. I have a good mechanical mind, but computers and electronics is takling me quite a bit longer to teach myself and truely understand things like how to map out the schematic righrt on ltspice. i will keep looking
This is the triode connected version.
- Tubes / Valves
- Vacuum Tube SPICE Models
