Pcb designer project 16,
Lower center *.point.
Traces not touching anything on pcb,
The pdf helps, but on the other hand you left the lid open so we can copy your style. Thanks
Ground plane round screws on bottom but not on top another great feature. eg
Got to go, so you have to wait.
New Group buy for USSA 5.0/5.1
Hi GumGum9000
I have copied the list started from one build thread and added your name. You can add your preferred pcb colour and the most popular one will be selected. This will be a small group buy this time.
List:
meanie - 2 pcs
Vunce - 2 pcs (Black)
GumGum9000 - 2 pcs
Fab
Hi GumGum9000
List:
meanie - 2 pcs
GumGum9000 - 2 pcs
Fab
Looks like I'm out again... I (currently) don't have the right speakers for it
So here is the list:
meanie - 2 pcs
meanie - 2 pcs
Hi GumGum9000
No problem. If you feel that the USSA5 at 25wrms /8 ohms in class A can not drive satisfactorily your relatively low efficiency speakers then you may want to try the FSSA2 (about 120Wrms/8 ohms and much more power in 4 ohms)😉
Fab
Fab
Any More Boards ?
Is it to late to the rodeo to get 2 boards for building the amp? After reading the tread I am very interested In building a amp since the transistors are still available without getting ripped for almost unobtainable transistors. Please let me know. Bob
With enough interest, Fab will produce another batch of boards,
this is the proposed list:
meanie - 2 pcs
Brianco - 2 pcs (any colour)
boba1000 - 2 pcs
Hi to all
With 10 pcbs production I could possibly get a reasonable price but not as low as previously with many pcbs.
Keep on registering here.
Thanks for your interest.
Fab
Fab
meanie - 2 pcs
boba1000 - 2 pcs
FAA - 2 pcs
boba1000 - 2 pcs
FAA - 2 pcs
meanie - 2 pcs
boba1000 - 2 pcs
FAA - 2 pcs
Funke 2 pcs
boba1000 - 2 pcs
FAA - 2 pcs
Funke 2 pcs
meanie - 2 pcs
boba1000 - 2 pcs
FAA - 2 pcs
Funke - 2 pcs
gary s - 2 pcs (any colour)
Running Total = 14 pcs.
boba1000 - 2 pcs
FAA - 2 pcs
Funke - 2 pcs
USSA5 small group buy
Ok, now we will have to wait a bit to reach a stable number before ordering...🙄 I suggest one week?
Can you also specify which version 5.0 or 5.1 you would like to build since the actual manual does not contain version 5.1 using bjt drivers instead of mosfet.
USSA-5 Build with Review
Fab
Fab
- Group Buys
- USSA-5 PCB GB
