meanie - 2 pcs (BJT)
Vunce - 2 pcs (BJT 5.1) 🙂
Brianco - 2 pcs (any colour) Yes Please 🙂
boba1000 - 2 pcs
FAA - 2 pcs
Funke - 2 pcs
gary s - 2 pcs (Toshiba mosfet drivers) (any colour) 🙂
Potstip - 2 pcs (BJT 5.1) 🙂
Running Total = 16 pcs.
boba1000 - 2 pcs
FAA - 2 pcs
Funke - 2 pcs
Fab
Am I too late to get a pair of boards with BJT drivers?
If not, put me down for 2 pcs BJT
Thank You
Brian
Thank You
Brian
Hi Brian
No you are not too late. Note that the USSA5 and USSA5.2 use the same pcb version.
I thought you already have USSA5 pcb?
Fab
Fab
Hi fab,
I am a bit confused as to what pcb does what, in the last few posts you mention the USSA5 and USSA5.2 use the same pcb. What is the difference in the 2 versions. I assume 5.2 is the latest pcb for the mosfet drivers?
Then there is mention of the USSA 5.1 for BJT drivers - have you published info on the BJT circuit and details of which transistors you are using?
In your opinion, which version is the best - maybe a hard question to answer, but I thought I would ask anyway.
Based on your answer, I might change from mosfet drivers to the BJT one.
Regards,
Gary..
Regards,
Gary..
Hi Brian
Fab
Hi Fab,
A different 'Brian'🙂
Yes, I have one set - but want another for a friend, hence my confirmed interest. I take it that the UK postage will be the same as for my USSAPA boards? If so I will add that same sum to my payment.
Gary
I am sorry I made a typo. Ussa5.2 should have read ussa5.1 and yes they use the same pcb.
It does not matter which version (5 or 5.1) I am curious who wants to try out version 5.1 with darlington bjt as driver instead of mosfet since I need to update the build manual for this version.. unfortunately I only have one channel mounted of USSA 5.1 so I cannot really test for sound comparison. However, v 5.1 was fully electrically tested fine. I believe that meanie and Vunce Have offered to build the version 5.1 after version 5 to compare.
I will publish the differences in parts between USSA 5 and 5.1 since it will be faster for me than to publish the updated manual (which will be eventually updated).
Fab
Fab
Hi Brianco
Yes price should be similar but maybe 1$ more since envelope and weight of USSA5 pcb is bigger than USSPA pcb.
Hi bfpca
You can simply add your name to the list.
Fab
Hi bfpca
Fab
Thanks for the update Fab, can you let us know the BJT parts difference before the pcb GB is closed in case I want to change my mind, but as you mention the pcb's are physically the same, so as I understand it there are not 2 different versions of the pcb to suit either the mosfet or BJT driver amp design - is that correct?
Absolutely correct, same pcb version for both USSA 5 and 5.1.
Bjt part numbers are: 2SB1259 and 2SD2081.
Fab
Fab
I want a pair too!
boba1000 - 2 pcs
FAA - 2 pcs
Funke - 2 pcs
mbrennwa - 2 pieces
Running Total = 18 pcs.
boba1000 - 2 pcs
FAA - 2 pcs
Funke - 2 pcs
mbrennwa - 2 pieces
Hi Brian
Fab
Yes, I have the original. Just starting the planning for the heatsinks/power supply/chassis. I’m trying to use parts I have in stock for this build. I want to support your efforts and also to compare BJT vs mosfet drivers going forward.
Brian
Ussa5 vs ussa5.1 comparison
Hi Brian
That is the spirit of Diy audio ! Thanks for your contribution
Please add your name with the smiley to the list.
Fab
Hi Brian
Fab
The output mosfet are Exicon
ECW20N20 (-S)
ECW20P20 (-S)
The distributor is Profusion. Quick delivery from U.K.
Fab
ECW20N20 (-S)
ECW20P20 (-S)
Fab
Would it be possible to modify the USSA5 to have balanced inputs (without adding a transformer or a BAL/SE converter unit)?
How difficult / easy would that be?
Hello,
if this is still running I'd like to add myself to the list please.
If OK I'll edit it and repost.
Thanks,
Max
Thanks,
Max
Hi Max
Yes it is still running until this weekend where I will order the pcbs. In the mean time ensure you have read 1st post before putting your name on the list.
Fab
Fab
Hi cool nose
You have PM too.
For all, please ensure to add your member name to the list before the weekend.
Fab
You have PM too.
Fab
- Group Buys
- USSA-5 PCB GB
