• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
USB to I2S 384Khz - DSD Converter
Today i received mine and here you see what pins are used for the F0,F1,F2 and F3.
And the back.
Thank you Domenico for your nice product.
Best regards George
From the images posted it's obvious that F0 - F3 are pins 17-20 and pin 16 is labeled D64 and that should be latest rev. board. So, be very careful with Acko reclocker boards because it's not fully compatible with this rev. One should remove connections - header pins on these positions to avoid connecting them to ground.
my card works very well with Windows but I have some problems with a Linux configuration (and a beaglebone card).
Here's the problem log (i think) on an arm ubuntu 13.04 :
ALSA sound/usb/mixer.c:1303 usb_audio: [10] FU [Combo384 Amanero Playback Volume] ch = 2, val = -32767/0/1ALSA sound/usb/mixer.c:1299 usb_audio: Warning! Unlikely big volume range (=32767), cval->res is probably wrong.
The output is louder than windows and noisy (it's like a crappy vinyl record 🙂 ).
May someone please tell me if a arm linux distribution or a kernel version works better ? (or something to pay attention to )
Thanks.
Still make Pop noise
Hello.
The pop noise when changing PCM to DSD mode were became small by update of the firmware, but, on the other hand, a pop noise came to appear between DSD to DSD file .
The noise did not come out in the old version.
Amanero-san.
I hope that the problem is recovered by the next version up.😉
By the way , Can I get firmware of oid version ?
thx
