I'm having the strangest problem this morning, could someone please verify the following for me? These are the pin assignments for the Amanero feeding a TI PCM5102.
Amanero Pin 3 - DATA to PCM5102 Pin 14 DIN
Amanero Pin 4 - CLK to PCM5102 Pin 13 BCK
Amanero Pin 5 - FSCLK to PCM5102 Pin 15 LRCK
Amanero Pin 6 - MCLK to PCM5102 Pin 12 SCK
Thanks in advance!
Thanks in advance!
Has anyone tested DSD with the new firm+driver?
Doesn't work for me-one channel of DSD works fine, the other channel is just noise. Works fine with any PCM, but new driver/firmware doesn't make DSD work for me. I suspect it might be a faulty board.
Don't know what to do now, tried everything but no L&R DSD which is why I bought this device.
@Supra, were you using a B-III?
My findigs were the same.
I am using a Buff2.
Not sure if I'm still on time, but I edited the spreadsheet to add another board to GB3 (45 units right now, only 15 more to go).
Brings up the question - is anyone getting good results with non-Buffalo DACs?
Another question- is anyone getting proper DSD operation, apart from GLT and his very complex foobar implementation?
Are there faulty units coming into the market?
Try to modify buffer length. In my case, works fine with little lenght.
DSD worked fine with standard Amanero and BIII before last firmware and drivers update, there only was the reversed channels problem but no noise.
DSD is working fine for me now using the setup detailed on glt's blog (great info - thanks) using current driver (version 1.056) and Buff2.
Supra - have you tried updating the firmware (Amanero Technologies)?
Those who still have DSD working, did you update both or just driver/firm?
Since both driver and firmware were updated in the system I tested I have no way of knowing which one broke DSD play or if it is both not playing along.
- Vendor's Bazaar
- USB to I2S 384Khz - DSD Converter
