• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
USB to I2S 384Khz - DSD Converter
I'm having the strangest problem this morning, could someone please verify the following for me? These are the pin assignments for the Amanero feeding a TI PCM5102.
Amanero Pin 3 - DATA to PCM5102 Pin 14 DIN
Amanero Pin 4 - CLK to PCM5102 Pin 13 BCK
Amanero Pin 5 - FSCLK to PCM5102 Pin 15 LRCK
Amanero Pin 6 - MCLK to PCM5102 Pin 12 SCK
Thanks in advance!
Doesn't work for me-one channel of DSD works fine, the other channel is just noise. Works fine with any PCM, but new driver/firmware doesn't make DSD work for me. I suspect it might be a faulty board.
Don't know what to do now, tried everything but no L&R DSD which is why I bought this device.
Try to modify buffer length. In my case, works fine with little lenght.
Those who still have DSD working, did you update both or just driver/firm?
Since both driver and firmware were updated in the system I tested I have no way of knowing which one broke DSD play or if it is both not playing along.
