• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
USB to I2S 384Khz - DSD Converter
After improvement of getting MCLK from XO instead of using standard PIN 6, I tried reclocking the BCK with same MCLK and the improvement is very positive. Right now I tied PIN43/44 on CPLD together, fed MCLK to reclocker and DAC with 2K resistor. The reclocker is 74AUC1G74 D-type flip-flop at 2.5V (power pull from 3.3V with 330ohm in series). Left side is PCM5102 DAC.
Hi, this is a pretty nice way to reclock the signal.
Does it work for high sample rate material? Is the fact that the BCK is delayed in comparison with the master clock an issue?
Thanks...
