Ural Warhead 1.1800 repair and overall health check
I haven't replaced the gate resistors so I assume they are original. The output FETs were the 31N20D before, replaced them with the 38N20D
They aren't heating evenly. on the high side 3 out of 5 FETs are heating up more, 1 specifically seems a little hotter than the other 3. on the low side all of them are cool.
All of fets are 431P date code, same assembly lot code.
On the driver board I replaced everything with their MPS equivalents (KSP42 replaced with MPSA42 and such)
All of the gate-source signals on the high side look exactly the same.
All gate resistors are close to 47ohm
Swap 2 of the high-side FETs, one hot with one cold. Does the heating follow the FET or does the heating remain with the hot FET's original location?
Have you clamped the FETs and tried driving a load to see if the amp would produce clean audio?
For the heating FETs, how hot and how quickly?
Today I won't be able to work on the amp anymore and tomorrow is Christmas, so most of the day I'll be doing other things, so I will swap the FETs tomorrow morning, also will try driving a load.
In about 2 minutes the hottest FET got to about 45c on the drain tab. Other 2 warm ones were about 35c. Cool ones were about 25c, ambient air being 22c.
