What rectifier diodes are worth upgrading in the power supply? And what numbers would they be on the circuit board?
I've already replaced all the reccomended caps in there with blackgate std's. I'm just looking for the next jump in performance without spending the $300.00 for the linear supply.
I stacked 3 1955 dac chips in total last night.
I can't say I like what it has done. There is more air and seperation between instruments and vocals, but the bass is too tight now.
Also when playing SACD there is a pop in between track changes and the noise floor seems elevated.
All of the eletrolytic caps in that area are still original. I've noticed that people have changed them for oscon and upped the values. I'm wondering if this is the problem. I don't know what caps or values to change?
Change resistors 3438, 3439, 3440 and 3441. Let me know what voltage you measure first though.
Regards,
Jon
I'll check in when I get home. If it's not, how do I adjust it?
Regards,
Jon
They both now read 2.4 volts after I fixed 4 lifted pins on the stack of dacs.JonHarrison said:Hi,
Have you checked the voltage at the output pins of IC7403 and 7404 (pin 1 and pin 7) ? It should be 2.4volts.
Regards,
Jon
However I noticed that pin 9 and pin 10 of the dacs are shorted together. I can't say I noticed before I fixed the pins if they were like that before. Pin 9 says analog ground and pin 10 says DSD Phase.
The player sounds great in SACD and regular CD. The musicality is back.
Don't worry that is correct, the DSD_PHASE signal (phase modulation mode) is not used and thus the pins SHOULD be tied low.
Did you have to change the resistor values to get 2.4V ?
Jon
Jon
Ah.. very good to hear that pin is tied to ground. I didn't have to change any of the resistors. 3 pins read 2.4 volts and one read 1.4 I checked all my joints with a meter and found 3 lifted pins on the 3rd dac chip. Once I reflowed those pins everything sounded great and all four power pins read 2.4 voltsJonHarrison said:Hi,
Jon
Thanks for all your help by the way. Do you think there is any improvement to be had by giving the output stage a linear psu?
Yes, absolutely , the +/-8V regulators are nothing special and the SMPS is noisy - just look at the supplies under a variable load with a scope. Certainly improvement to be heard if you were to fit a seperate supply with (discrete) linear regulators having feedback bandwidth into the MHz and low output Z. A Jung style regulator would be good but even a simple Sulzer type or in fact any op-amp based discrete linear regulator fed by its own supply would be better than what is there at the moment. You may not even have to go to that extreme to get an improvement, just fit a seperate supply with a pair of standard pos and neg 3 pin regulators and listen to the difference.
Jon
Jon
Re: Install linear PSU
Jon, Is this correct?sugarn said:Hi Saffier,
How to install linear PSU.
1. Remove jumper #4604
Jumper #4604 is tiny and is next to the negative side of cap #2619 on the top of the AV board. When you remove this, you isolate the -8VA line for the op amps. The original -8V regulator is still used for various digital pulldowns.
2. Remove jumper #4606
Jumper #4606 is also tiny and is on the bottom of the board ~1 cm from resistor #3659 (which is ~ under cap#2612) in the direction towards part #7502 . This will isolate the +8V op amp supply. You can check with a DVM that you have the right ones.
I did not remove caps #2612 and #2613. These caps are needed to bypass power supply noise to ground. I also did not remove resistor #3659, regulator #7601 and #7602 at this time because it's still needed for digital circuit power supply.
You should check +8v supply on OPAMP AD8032 pin 8 and -8V on pin 4 to make sure that it’s now isolate from regulator #7601 (+8V) and #7602 (-8V).
To make sure that you’ve done correctly you can turn power on and check voltage at pin 8 and pin 4 of OPAMP 8032, it must have 0 volt.
3. Prepare linear regulated PSU and adjust to +8 and -8 volt. You must not connect to 963SA mainboard at this time, but first check voltage output of the new PSU to make sure that it has +8V and -8V before connect it to the mainboard of 963SA. Check positive output and negative output voltage terminal on new PSU with its own ground, not to mainboard ground because we still don’t connect to 963SA mainboard at this time.
4. Connect +8V regulated from new linear PSU to pin 8 of OPAMP 8022 which is at bottom of the mainboard.
5. Connect -8V regulated from new linear PSU to pin 4 of OPAMP 8022 which is at bottom of the mainboard.
6. Connect ground from new linear PSU to mainboard ground. You can connect to any ground point on the mainboard. I connected to + of caps #2619. You must make sure that you connect to mainboard ground, not to + voltage supply rail.
7. Turn power on and check voltage at pin 8 and pin 4 of OPAMP AD8032.
That’s it well done. I’ve successfully installed linear PSU at first try, no any problems.
To further improve digital circuit power supply, I have removed resistor #3659 and connect +12v DC unregulated from new linear PSU to + of caps #2612.
Link 4604 isolates the -8VA supply from IC7602 (MC79M08). L4606 isolates the +8V_OpAmp supply from IC7601 (LF80C). The advice not to remove the caps 2612 and 2613 is correct although they are there as reservoirs - not for decoupling as stated.
+8V_OpAmp and -8VA feed the I/V opamps IC7403 / IC 7404 and the output buffer IC7405 as well as the analog switch (scart / surround) IC7400 and the LM833 opamps IC7401 / IC7402 and NE5532 IC7501 / IC7502 used for buffering the scart and surround sound channels.
If you're not worried about the surround channels you could remove R3501/3502 to isolate the new +8V supply and R3504 / R3505 for the new -8V supply then connect these with the same 10R back to the original +/-8V regulators.
R3659 is in the supply feeding IC7601. This in turn feeds IC7603 (LF50) which supplies +5VA. +5VA supplies the analog side of IC7300 (the Crystal CS4362 used for the surround sound DACs) and the analog side of IC7301 AD1955 (the main stereo DACs) so the comment that it improves the digital circuit power supply is incorrect, it is still the analog circuit.
The commonly used recipe for a linear supply here seems to be +/-9V (AC) 1A transformer , bridge , 0.25A fuses , 2 x 1000uF BG standard, NJM7808FA and NJM7908FA then 2 x 470uF BG standard. I wouldn't use the blackgates personally, Panasonic FC / Rubycon ZA,ZL or similar bypassed with polypropylene.
The size of the fuses give you a guide to the current but you could try and measure the volt drop across a low value resistor, you'll probably measure mV though. I'd guess at 10's of mA on each rail.
Regards,
Jon
Regards,
Jon
I see, so it's fine to attach the new - and + 8V supply to the power pins on 7403 or 7404 once I remove 4604 and 4606?JonHarrison said:Hi,
I'm going to use a lm317 based design mainly because I have the parts alreadyOriginally posted by JonHarrison The commonly used recipe for a linear supply here seems to be +/-9V (AC) 1A transformer , bridge , 0.25A fuses , 2 x 1000uF BG standard, NJM7808FA and NJM7908FA then 2 x 470uF BG standard. I wouldn't use the blackgates personally, Panasonic FC / Rubycon ZA,ZL or similar bypassed with polypropylene.
I'm guessing 375 ma from each secondary of the transformer with a 0.250 amp fuse on the primary side will work fine.Originally posted by JonHarrison The size of the fuses give you a guide to the current but you could try and measure the volt drop across a low value resistor, you'll probably measure mV though. I'd guess at 10's of mA on each rail.
Regards,
Jon
I'm planning on just using a switch in the back to turn the supply on and off. Is there a better way?
Yes, or something connected to the power pins.
You could use a relay from the +12V supply to switch it.
Jon
Jon
Yes, when current from the +12V supply flows through the relay coil it attracts the armature and closes the relay contacts, the contacts are used to switch the linear supply on. Don't forget to fit a diode backwards across the relay coil to clamp the switch-off spike.
Jon
I've never wired a relay before. Can the +12Vdc line be used to trigger only DC power?
Jon
Is anyone willing to share your copy of 963SA schematic with me? I'm modding mine according to the excellent recommendation posted here. Replaced some cap in SMPS with BG and I love the improvement. Now I'm proceeding to the components on AV board and a schematic would be very useful to learn and make sure what I'm going to do.
So could anyone of you kindly share your 963SA schematic with me? Thanks in advance
Wallace
Wallace
- Digital Source
- Upgrading Philips DVD 963 SA
