Looks better than before.
maybe, but the lighest overload and You will be kicked off the saddle, like when mounting a raged bull, try some 1.7V input and will see
To do this, a threshold limiter is introduced on the diodes.maybe, but the lighest overload and You will be kicked off the saddle, like when mounting a raged bull, try some 1.7V input and will see
You mean this raged bull?
As I'm waiting for heatsinks for Wiederhold77 HexFet Quasi,
I simmed VHex 1 from Valery, recommended by Egra.
I don't know if I'm doing it wrong, but here are the results.
With these numbers, it looks like op-amp is really improving
things...
I tried different transistors, but no improvement was possible.
things...
Parallel to R14, put a capacitor with* 22nf-100nf, the clip will become normalYou mean this raged bull?
🤣 Yes
Change the oramp model in LTS .
It didn't help.
Also, subsequent simulations show not difference if done with or without R14. So, according to your previous advice, I removed R14.
The clip oscillations become better if I change the diodes to Schottky diodes (E.g. 1N5817), but it does affect Thd slightly...
So I guess that's not the way...
As for the model - in the sim I'm using LT1056 - built in into LT Spice.
In actual builds, I tend to use TL071.
I have a model for TL071, but if I use it - my .asc files will not work for you guys - op-amp models has to be imported into LTSpice directory tree, they are handled differently than transistor models from .lib files.
3rd party op-amp models are very awkward to use.
Perhaps I could use different op-amp model, that's built in into LTSpice standard library...
@Maxim. Since the missing parts are already on way from mouser, I would like to finalize the circuit of qhex version and I'm going to design the PCB. The amplifier shows ugly clipping characteristics when R1 = 33 Ohms are used. It looks much better with 100 Ohms (In original Wiederhold it is 1k). What do you think? Also, since I don’t have enough knowledge in LTSpice, could anyone simulate the Phase and Gain margin of the circuit? Currently I only have +/-33V Power Supply. This is why I set the simulation to 33V. Thank you for the help.
capacitanc7 should be increased. 22PF
It is necessary to select it.
C12/c13 can also be increased
( It looks much better with 100 Ohms (In original Wiederhold it is 1k)]750ом УМЗЧ ВВ и СЛА
Egra, you are adding zener protection for the gate of M1, but not M2?
When I was selecting R1=33 Ohm, I did not test for clipping....
Depending on the Vpp of your audio source (I was assuming up to 1.2 V AC for my needs) - you may need to
increase R5 910 Ohm resistor to achieve lower gain - since you are using lower rail voltage.
910 Ohm was already aggressive
1k or 1k2 might be better.
910 Ohm was already aggressive1k or 1k2 might be better.
22 ohms in supply rails caused the clipping problem. So I left them, now everything seems right. I think it will be good already, I'm going to design the PCB. Minek, did you simulate Gain and Phase margin?
You were referring to the circuitry in #259, weren't you? I'd not short R13, but bypass it with a 1N4001 Baxandall diode instead.What happens if you short out R13
Best regards!
- Unusual amp from 1987
