Understanding load lines
Joined 2004
Joined 2009
OPT specs taken from Edcor web: http://www.edcorusa.com/gxse5-15k
Wattage 5W
Max. Current 100mA
Primary (input) Impedance 15K Ohms
Screen/Grid Tap 40%
Secondary (output) Impedance Depends on model.
Frequency Response 40~18K Hz., <1dBu
THD+Noise <0.1% @ 1K Hz.
Bobbin Material Nylon 6/6 GF-30
Flamability Rating Class B 130°C
Core Material M-6 29 ga. grain oriented lamination steel
Secondary Insulation (transformer) Clear air dry polyester varnish
Termination 0.187" (3/16") quick disconnects
Mounting Zinc plated steel channel/frame
Weight 1.2 lbs.
Compliance RoHS & REACH
Joined 2008
For example I want to understand the load line for 5687 tube, I have 209V as B+ and 10K as load anode resistor.
To know the plate current is to divide 209V : 10.000 ohms = 0.0209 A = 20,9mA.
Now I draw a line between these points to get the load line, If I choose the operating point at -3V as grid voltage the tube will draw 12mA, right? If I want each tube draws 10mA the grid voltage have to be -4.5V? The best OP is -7V as grid voltage?
How to know the best plate current for each tube?
Hi Merlin,
You might also find Paul Joppa's article on Operating points helpful. They are from Bottlehead's magazine archive of Valve: 1998 Vols. 3,4,& 5.
PRR
Joined 2003
I agree. Many posts and still not putting 3 parts together so they will work.
There is a vast body of information on Basic DC, AC theory, and then (only when you have mastered DC and some AC) Amplifiers. This must exist in Spanish(?), but it is clear you are fluent enough in English to read and digest electric and electronic theory in English.
Asking us to type-up very basic explanations of very basic design hurts our fingers and my back/leg.
