• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Ultimate Twin TDA1541a Non-oversampling DAC with tube buffer & reclock set.......
hi jleaman,
do u always diy cables.
I had some new solder which will later prepare groups buy is made by
LMP series Ag(3%)Cu(0.8%)Sn(95%)Ni&Ge(0.06&0.1%) to solder.
I ordered all were 0.8~0.1 diameter one, U can use 25wats solder to sold.
This solder had max melting temp in 227degree. Will easy to solder & not easy to cause oxized for the silver core.
do U had address. let me post small sample for u to try.
do u like it.
thx
thomas
tube-lover said:
hi jleaman,
do u like it.
thx
thomas
Didn't i just buy stuff from you on ebay i could have sworn i did :0 but please contact me at jason at zorby-audio . com and we can talk id be interested in buying some for sure.. I make lots of cables and hope to at least make them to sell and make a little money to help pay for my projects that are on going and to continue to learn more and more 🙂
j'
hi, jleaman,
pls directly email to me. I will good offer to U.
may be the another type silver cable I will let U try first.
They contain several size of the solid core inside the cable. also flatline. Last week during new year holiday. My friend take the silver speaker cable to compare with his nordost silver flat line to compare. Only a little different. They both worl well in horn speaker, voice coil copper cable will be better.
thx
thomas
Hi Thomas,
Thank you for the offer of the OPA627 and the silver cable. As my DAC has not shipped yet (I assume I'm one of the DIYers who have been waiting a long time :xeye:) can you include these parts when shipping the main DAC.
You mentioned that there is extra postage from the factory to you as well as shipping to the DIYer, so I'm happy to pay for your costs to ship from factory to you (but assuming there is no extra costs from you to me as you have to ship to me anyway).
Dean
Ultimate Twin TDA1541a Non-oversampling DAC with tube buffer & reclock set...........
Hi deandob,
sure, I will free to silver cable to u. U only like to payapl the posatge or the cable. This is the price that from factory to me. USD 15 was Ok because I will post to U with cable. But I must collect U the handcraft & psotage that factory chage me.
I also prepare the Output transformer for the DAC.
for 417a & 6c45
USD 155 inclde posatge to diyers.
Pls understand the postage was approx USD 45. paypal ust ay charge .so the pair of the pre-amp output was USD 105 per pair only.
Had 3K/5K pri-30ma.
sec was parallel 600ohm.
it means 600ohm X2.
parallel =600ohm.
series will 2.4K.
wire was use furukawa RMA japan.
wire for the sec was special ordewr from japan high purity copper 4 wire parallel to gurantee the sec was full balance.
pls see the photos.
I means diyers can running parallel form, 600ohm output & 2.4K output.
Use Z9 0.22mm lamination & 2.1 kg per pair.
OEM by Daburu.
This is actually a pre-AMP OUTPUT transformers. U can keep it for
another projects.
At least will better for 417a, 5842, 437a CV5112 6c45.......... & C3m preamp.
thx
thomas
Hi Thomas,
I have read all the posts on your dac kit and have been thinking about ordering one. From reading your post yesterday do I understand correctly that you will be offering this kit at a price which is 20% less than it is now with a group buy? If yes do you know when this group buy would likely happen?
Thanks,
Mark
Hi Anthony,
I had 8 sets on hand, will ship this several days since the OPA627 will arrived this several days.
I will email to u when 627a arrived. I will post yor kit with the opa627 whic was the most update one.
markgall,
I was testing another project.
this is TDA1545a NON-DAC. also contain reclock( Use TCXO but will be same 1.25ppm). If diyers did not like to use. Can short for it. & running in NOS mode.
I was testing parallel 4~8 pcs. All this will had Optical input. may be later kit will same too.
This dac was running with 8 AA battery about it. I thought many diyers had re-chargble AA battery on hand. Use 8 AA battery at least can running two days.
Kits will follow with funis Dac, batery mount. optical or USB input.
My solid silver core digital cable will use in the digital input. 1feets only.
I will be same use nano pulse trans into the dac.
Pls let me know any diyers will had interest. Because its a group order. Price will below USD 110~120 include posatge EMS worldwide. This also one sound card price.
All will factory funish. But I need to accumulate the order.
so i guess must groups buy.
I will step by step to say the total order, when will handover.All will refer the factory. But I guesss will after stop all the groups order. I can send the gerber file to factory. open production line. I guess within 6 weeks can handover to all ordered diyers.
thx
thomas
Hi Thomas,
How's the 'Hum Issue' with the TDA1541A kit? Hope you can fix it soon. You have new PCB's already?
Is Reclocker included?
Do you provide a PCB with 417A/5842 OPT tube output ONLY?
I only want 1 pair of tube outputs for simplicity. But there are 2 pairs of tubes in the attached pic (switchable?):
http://www.diyaudio.com/forums/attachment.php?s=&postid=670678&stamp=1119846894
Do you have good picture of the enclosure/case tha will fit all the Transformers (spdif input, signal chokes, etc?).
Thanks. 🙂
fred
For the hum reason, I will follow with new pcb which was new design tube buffer.
this means U will get total two tube buffer because some of the PCB had hum, some hadn't. I will post one new PCB to all buyer. if they had hum, they can use the new buffer. if not, they can use the Old one.
is it good ??
thx
thomas
Re: Ultimate Twin TDA1541a Non-oversampling DAC with tube buffer & reclock set...........
is it good ??
thx
thomas
How much for new pcb ? and can i re-use my older parts ?
Hello Thomas,
Happy new year!
I had a different experience with the Audio Note silver pulse transformer. I ended up going back to the original one. I thought that listening fatigue increased with the Audio Note transformer at the S/PDIF input. I believe it increases jitter in the digital connection.
I'm interested in ordering your new TDA1545a DAC. Please count me in in a group order.
I'd also be interested in your new tube buffer circuit if different than the old one. And the new 2002 TDA1541a DAC chips you have. Please let me know.
Were you able to send me the TCXO and new nano transformer? I'd really like to test these parts in my twin DAC kit.
Thanks.
