Ultimate Twin TDA1541a Non-oversampling DAC with tube buffer & reclock set.......
this is recent item I will get it & will goood for all diyers.
VTV Tantalum resistors.
price will good for diy pre-amp, dac IV area.
thx
thomas
synchronous i2s feed
I have not experimented with the v2 clocking boards. What I would like to do is to take an i2s signal from a transport, but feed the transport with a Tent clock that is inside the dac (synchronously). The i2s signal coming into the dac would be reclocked before the tda1541 chip.
Can I accomplish this with either of the 2 reclocking boards Thomas including in the v2 kit?
Re: synchronous i2s feed
If you use I2S interface you should install the Tent clock into your transport and keep the I2S connection short then I think no need for further reclocking.
The reclocking boards provided by Thomas are designed to be used with a receiver chip e.g. cs8412.
hi all,
full balance 1541a with USB receiver test funish. Thiswillbe the best 1541a that I made. I trust that no more 1541a will arrive this standard.
It actually funish by Two DAC, use CPLD ( Two Pieces) & prevent no time delay, no phase shift for it.
More input,
USB, TTL, BNC,RCA.XLR,OPTICAL.
standard DAC such as so many dac use one CPLD to recerve the signal from + to - but this will cause time delay & phase.
this DAC will not.
take a look for the circuit first.
thx
thomas
  • dac.pdf
