Ultimate Open Baffle Gallery
Hi SDF - Looks very nice so far - I'm interested because I also use the ESS AMT1 mid-tweet on my speakers. Please share what you are doing for cross-overs and listening impressions with us. I keep looking for where you have hid the wires:smirk:
Also - your impression of having the AMT mounted into the baffle - I intend to do mine with the it simply mounted on top.:cheers:
Is your mounting of the AMT a bit recessed from the baffle to align it with the wooofer? Clever lad - I like it!
Hi c2cthomas !
About crossover, I've just made some tests only.. and in the simplest way, using DCX2496 (...the easiest solution😱) It allows too, to adjust phase (delay)
For the wire 😀... I have not yet installed the binding post which will may be neutrick speakon socket in fact..I don't have make my choice 🙄
..all in all, I've trying to find a good compromise, to me, between design (not too big, not too ugly...) and "performance" so I don't planned to use the PHL2460 (8feet driver) under 120Hz!
Thanks for your kindly comments 🙂
SDF: what midrange driver are you using there? Looks like a 10" (?)
I would think that you'll get better polar response from the ESS/Heil driver by just putting it on top with no baffle? Thats what ESS did with it, and I think it a good idea.
I use PHL2460, it's a 8".
Welcome on PHL audio web site
http://www.lsv-achenbach.de/images/lautsprecher/test/hh_test_phl2460.jpg
http://www.lsv-achenbach.de/images/lautsprecher/eigene/son/kt_phl2460test.jpg
...and better again will be the ESS stand alone because it won't be disturb by vibration of the baffle (which decrease the precision of treble) but in my case I don't want cause it makes the speakers ugly 😡
I have a pair of PHL 2520 8" midrange drivers that I bought used. Do you know anything about them? I've been thinking about trying them in an open baffle/dipole design or an open back midrange-type design.
Soooo cute, isn't it?
Taken from
http://www.diyaudio.com/forums/multi-way/159731-beautiful-swingin-speaker-3.html#post2110689
