Ultimate 4U 500mm Chassis - Who is interested?
Base Plate Option
  • Standard Aluminium 3mm or 4mm
    Votes: 5 23.8%
  • Aluminium + Custom Perforated Steel Base Plate 470mm to 480mm
    Votes: 16 76.2%
  • Total voters
    21
  • Poll closed .
The first chassis that I recently ordered is reserved for the SIT-3X. Thinking the big SIT hockey pucks can make good use of the large heat sinks and the interior room will allow for some serious bulk bypass caps.
The second chassis is still under consideration. The most recent Stasis boards look very interesting, and something different to try. I still have a pair of 2SK180 SITs that need a good home, so there are a couple designs to consider for those as well..
I revised the front end of Papa's original Sony V2.
So that will definitely be one build.
I've got a stack of lateral mosfets so will probably do an output stage that will go with the Front end above.
Then a redesign of another Papa amp.
So at least 2 and maybe another 2 after that.
