UDNeSS, or You don't need Semisouth's
Simulation is a very useful design tool to allow you to vary parameters.
Mordern-day engineering can hardly do without simulations, whether in Space or in F1.
Of course you always need to check against reality.
Simulation is only as good as the model you use.
And THD also does not tell you the entire story about how it sounds.
And how it sounds vary from one person to anther.
Patrick
Ah, well, my question was not about "how does it sound", that would be asking way too much! I was more interested about the fact that the original idea for the J2 was to use the SemiSouth parts instead of the IRFPs, because the SemiSouths allow lower distortion. This is in contrast to your simulation, which seems to indicate that the IRFP version has similar (if not lower) distortion as the SemiSouth version.
If you read the article carefully, you will know how the lower transconductance of the IRFP is being compensated by the increase in input stage gain.
All information have been published and explained.
I can also show a simulation where the distortion is 10x lower by increasing the OLG further by a current mirror.
In a very similar way that opamps has ultra low distortion of < -120dB.
But that is not the purpose of this exercise.
Patrick
I was asked if an NMOS version would work.
I was not going to publish this, but yes it will work.
You will need unobtanium 2SJ74or 2SJ109, but you can still get those in GR grade (min 4mA Idss).
Since it is the UDNeSS with reversed polarity, it will have to be called RUDNeSS.
Patrick
  • RUDNeSS V1 THD.asc
Some progress.
Patrick
