UCD 25 watts to 1200 watts using 2 mosfets
IRS2000D by Thienchay
To chago25,please check
Hi jancso2002 the one i post is intended for chago25 for part's placement reference only not the P.C.B. layout.Don't be confused,if you already build the IRS900 then compare that layout to the one i post and you can see the difference.(please notice the P.C.B. layout)thank's.
I do not confuse the scheme IRS 900 to IRS 2000, I wanted to say that even with modifications IRS 2000 base-emitter of transistor 2nXXXX not go into oscillation only periodically (PCB by Tien ....)🙁🙁🙁
Hi to all
HI sir manoj
sorry for my late
i have hisssss in my amp
when i conect gnd from my car cd payer to your amp gnd then it have hummmm
i try turn on your amp without power section
i use one lm7812 for bias but it dose not worked. why?
i cannot find out the amp FERQ beacuse i dont have that divases
how much value resistor for change FREQ
i need change over curent and short circute optione too. which resistor was do this to me?
thanks
Hi to all
HI sir manoj
sorry for my late
thanks
short question
what amp do you have build ?
can you send me schematic
